Tom Senior Motor
Tom Senior Motor
Home Forums Manual machine tools Tom Senior Motor
Viewing 7 posts - 26 through 32 (of 32 total)
  • #212935
    Tendor
      @tendor
      Hi Hywell, Good job. Recommend that the new leads from winding ends to junction box also be laced to the existing windings to avoid movement and fatigue. Then some varnish on all modified wires. Polyurethane would be better than nothing.
      Hevanscc
        @hevanscc
        So, the motor is now connected and the wires tied to the windings – I used some polyimide tape as well as PTFE – and varnish applied. Now I'm waiting for the inverter to arrive from Drives Direct before testing.
        I am getting on with the rest of the refurb and, as these things tend to, it is escalating past my initial intentions. Completed an initial degrease and powerwash of the base, chiptray and other disassembled parts today ready for stripping and sanding. I have a couple of questions which I would be grateful for some advice on:
        1. How do I remove the vertical leadscrew from the bottom of the knee? It seems to be located in a bushing which is attached to the underside of the slide by three allen head bolts. These are not easily accessible so I am thinking that taking these out is not the correct approach – or is it?
        2. The leadscrews and worm gears were all liberally covered in grease. My understanding is that grease should only be used for bearings, and oil used for exposed parts like leadscrews and gears because it doesn't collect swarf like grease. Any opinions as to what to lube with on re-build?
        3. The inside of the base was quite rusty and the suds tank full of who knows what. I have cleaned this out and powerwashed it. I could get it sandblasted but this means I would have to take it there and the cost is not trivial. Given that the inside will be hidden away so a perfect finish is not important, I just want to protect the metal so plan to treat it with kuurst, or similar, prime with zinc phosphate and paint on top with Stationary Engine Parts enamel. Does this seem a sound plan or is there a disaster lurking in it somewhere?
        4. The outside surfaces I plan to strip with a polystrip disc on an angle grinder before priming and painting. I haven't done something like this before so hoping that it is a sensible approach . . .
        Thanks
        Hywel
        #213528
        Tony Simons
          @tonysimons69671
          Hi Hywel
          I stripped mine using Nitromors paint stripper. Given the age of the machine I was concerned that the paint contained lead an didn't want to cover all the workshop and my lungs with the dust. In actual fact the paint came off easily. I painted the inside of the suds tank with a gloss paint, given that it wasn't going to be seen I used a tin of yellow that I had on the shelf.
          I undid the casting from the base to release the vertical screw rather than the allen keys.
          The gears and leadscrew on mine were coated in grease, plan to use oil on re assembly.
          #213551
          Tractor man
            @tractorman
            Hi hywel. I refurbished an M1 and published an article in MEW a few years ago about it. It’s a cracking machine and does a sterling job. I just painted the suds tank gloss but don’t use it. I use mine as a horizontal mill full time as I don’t have the vertical head. If you have any questions drop me a line. T
            #214030
            Hevanscc
              @hevanscc
              Posted by Tony Simons on 21/11/2015 20:42:21:
              Hi Hywel
              Tony,
              I took your approach and hit it with paint stripper. It has gone pretty well with one problem. The aluminium rear cover has a thick black layer of filler type material over it, presumably to give a smooth finish to the rough casting. The paint stripper would take ages so I am in two minds whether to leave it, sand and prime over or remove it with the grinder but then have to fill all the bumps and hollows again. I am also concerned if it will react with the etch primer I intend to use. did you encounter this problem?
              Hywel
              Edited By Hywel Evans on 25/11/2015 08:54:10
              #214092
              Tony Simons
                @tonysimons69671
                I encountered the black filler like material on the inner sides of the drip tray as well. I removed it from the tray by scraper and a bit of heat. The rear cover I just sanded smooth and repainted, I didn't bother stripping it.
                #214238
                Hevanscc
                  @hevanscc
                  The inverter arrived so I put the motor back together and wired it all up temporarily. . . . and it worked! Turned it on and the motor started, increased the speed and the motor went faster. So far so successful – I will have to wait and see how it performs when hooked up to the mill after I finish painting and reassemble. Thanks to everyone for the excellent motor advice.
                  Hywel
