Tightening a Threaded Bolt
Home › Forums › General Questions › Tightening a Threaded Bolt
  • #560987
      Posted by William Harvey 1 on 02/09/2021 18:15:00:
      Not sure?
      On the side of the Tap it just says '3/8 NF 24'
      Most likely then, that it is the ‘general purpose’ Class 2B
      … and also likely that the original thread was Class 3B, to match a high-tensile bolt.
      The tap would therefore take-out an extra ‘lick’ of metal … giving the result that you have observed.
      William Harvey 1
        @williamharvey1
        Posted by Michael Gilligan on 02/09/2021 20:20:25:
        Not sure?
        So it now needs a Helicoil but to the correct thread for the HT bolt?
        #560994
          Posted by William Harvey 1 on 02/09/2021 21:15:25:
          That would probably depend upon how “slight sloppiness” is quantified
          … Sorry, I can’t advise
          William Harvey 1
            @williamharvey1
            So, I tested the bolt and torqued everything up to the recommended figure which I believe was 52Nm.
            Torqued up fine, so I'll leave it at that.
            I did not use the lock washer, but will do on the final build, also some Loctite 216.
            #561372
              yes
