Thickness of Bahco Sandflex 12″ hacksaw blade.
Home › Forums › General Questions › Thickness of Bahco Sandflex 12″ hacksaw blade.
  • #143371
    Chris123
      @chris123
      Can someone measure the thickness of the teeth side of a Bahco Sandflex 12" hacksaw blade please.
      I need the teeth side of the blade to fit into a slot.
      Thanks,
      It's this blade:
      http://www.axminster.co.uk/bahco-sandflex-h-s-s-hacksaws-blades
      And this is the measurement I need:
      #23138
      Chris123
        @chris123
        #143382
        Thor 🇳🇴
          @thor
          Hi Chris,
          mine measured 1.13mm.
          Thor
          #143391
          Chris123
            @chris123
            Thanks for taking the time to measure.
            Although I've just been to a shop and measured one myself and it was 0.93mm! I didn't buy it as they were £3 each!
            maybe there are different types?!
            #143394
            Sub Mandrel
              @submandrel
              The set, which determines the width of the cut or kerf, will depend on the number of teeth per inch of the blade. A coarser blade will have a greater set and produce a wider kerf.
              As you've probably noticed the set on a hacksaw blade is produced by giving it a wavy edge, rather than by bending the teeth to the left and right as on a wood saw.
              Axminster do them in 18, 24 and 32 tpi at £1.44 each, including VAT.
              Personally i swear by Starrett blades, when I can get them.
              Thor 🇳🇴
                @thor
                Hi Chris,
                sorry I forgot to mention that the blade I measured had 18 teeth per inch. I also measured a Starret blade (also 18 tpi), it measured just under 1 mm, so it seems that different manufacturers use different blade widths.
                Thor
                #143398
                Chris123
                  @chris123
                  Sorry, forgot to say it was the 24T blade I need!
                  axminster is a long way from me unfortunately and I need some today!
                  thanks anyway.
                  #143399
                    Posted by Stub Mandrel on 10/02/2014 11:47:16:
                    Neil,
                    I'm with you there !!
                    For info. … Starrett sells direct from the website
                    Well worth checking from time-to-time, because they've had some excellent offers.
                    AB658
                      @ab658
                      Good luck with this one! Measured 2 new 24T blades & got range of results….major difficulty is wave form in addition to any individual set, so where you position measuring implement is crucial. Measured longitudinally along the teeth, my digital vernier gives 1.07/1.08 at the LH end (24 TPI printed) & 1.16 at the RH end. Random measurements at 90 deg to the blade gave 0.79 to 0.84, except in the outermost inch or so where I got up to 1.20……tried a mic as well, but the between-waves/across waves variation was even worse.
                      Adrian
                      #143412
                      AB658
                        @ab658
                        Second thoughts: as I am, literally, without parallel, I used a pair of engineers' clamps placed side to side with the blade in between & measured across the sandwich. The average of the calculated results, within 0.02 of each other, was 1.03mm. If you have a height gauge & surface plate you could do something similar. Adrian
                        #143420
                        steamdave
                          @steamdave
                          I swear AT Starrett blades. Bought a bunch of bi metallic ones some years ago and the teeth seem to just Fall off, regardless of the tension put on the hacksaw frame.
                          The Emerald Isle
                          #143441
                          ian cable
                            @iancable23486
                            mmm definite problem there then ian c
