To determine whether the problem is just simply one of rising hot air may i suggest that you get a thermometer & with the fire on full. Leave it to get fully heated. Then you take a range of say 20 readings up the wall ( make some marks to record the positions) above the fire & say 1 inch from the wall & tight against the wall.
Then temporarily place a sheet of ply at an angle of 45 degrees tight to the wall to form an airtight seal & the next day repeat the process & then measure the temperatures at the same points on the wall & just an inch away from it
It will give you an idea of what you are up against temperature wise & if it is rising air that is carrying the heat up the wall
Edited By Sam Longley 1 on 23/03/2018 21:58:43
