The right sort of paint!
Home Forums Beginners questions The right sort of paint!
  • #379085
    Kevin Murrell
      @kevinmurrell62078
      Dear all
      Having spent ages restoring a Stuart 500 boiler, it was steam test today. Few leaks where I had forgotten to tighten bolts, but otherwise fine. However, the paint I used on the outside panels bubbled up and flaked off! Oddly the etch primer underneath seems to be OK. The panels are insulated, but of course get hot. What paint should I have used? (I think I used simply Halfords car paint). Not keen on hammerite as I have had problems before getting smooth matt finish.
      Link to pictures: http://www.ps8steam.co.uk/stuart-500.html
      Edited By Kevin Murrell on 04/11/2018 12:20:34
      #9397
      Kevin Murrell
        @kevinmurrell62078
        Boiler paint
        #379089
        Hopper
          @hopper
          Heat resistant engine paint from the car parts store works well. It sticks to motorbike cylinders so should stick to a boiler. Not usually used over an etch primer though so you will have to experiment with that.
          If paint color is black, barbecue paint is pretty bulletproof too.
          #379091
          Oldiron
            @oldiron
            Hi Kevin, E-tech heat resistant engine enamel is good. Or in a smaller colour range at car shops is VHT exhaust paints.
            regards
            looks like Hopper beat me to it
            Edited By Oldiron on 04/11/2018 12:39:27
            #379094
            Ian Parkin
              @ianparkin39383
              Barbeque paint works well
              from b&q
              sorry missed Hoppers suggestion
              Edited By Ian Parkin on 04/11/2018 12:52:44
              #379096
              GoCreate
                @gocreate
                I used Precision Paints enamel on my 3" scale traction engine cleading which has 4mm insulation. I've only steamed it for 1 year but no problems with the paint. However, if you can get the heat resistant paint mentioned above in the colour you want then go with that.
                Nigel
                #379103
                Brian G
                  @briang
                  We sprayed a 16mm loco with U-Pol primer and Halfords (acrylic?) car paint, looked fine until the loco was run, when the paint on the boiler cladding started to soften and bubble. I have heard that baking it for some time immediately after painting helps, but haven't tried that yet, instead I will probably try to get some cellulose paint or enamel. Heat resistant paint on the smokebox seems to work OK over etch primer though.
                  #379117
                  Ron Laden
                    @ronladen17547
                    I do know that E-Tech car engine paint is very good, well on car engines anyway. You can find it on Ebay, I think it is said to be good to 250 C.
                    #379128
                    Anthony Knights
                      @anthonyknights16741
                      Machine Mart do a heat proof paint for stoves. Only available in matt black but heat resistant to 650 degrees C.
                      There used to be Cylinder Black for motorcycle cylinders. Probably still available from motorcycle shops.
