Re the Warco WM280 lathe.
On the face of it, it looks good, but I would comment on the following:
My lathe has a centre height of 110mm and a X-slide travel of 110mm. The WM280 has a centre height of 140mm and a X-slide travel of 140mm. In my albeit limited experience, the X-slide travel is not enough. In my case an additional 20mm would certainly be advantageous as if turning at maximum diameter, the X-slide is just about off it’s screw. I imagine the WM280 will be similar.
Distance between centres: 700mm. Longitudinal travel 550mm. ???
Metric & imperial threading is quoted as 0.4 3.5mm and 8-56tpi. My lathe, a smaller lathe, has 0.4 – 12mm, and 3-72tpi. Now I don’t know if these extreme figures are necessary, certainly I have never had to use them, but it just makes me wonder.
Finally, the speeds are quoted as 50-950 & 100-1900rpm. Now, there has been comments elsewhere about these electronic minimum speeds actually being down on power so I wonder just how useful they actually are. In addition, with a centre height of 140mm one could expect to be able to swing in excess of 250mm, eg a locomotive wheel. Now from what I can see in the Model Engineer’s Handbook, the lathe can only turn wheels made from soft or easily turned materials, eg aluminium, brass or free-cutting mildsteel. For anything such as cast iron, a much, much lower speed is required. Which, I suspect, is why the Myford Series 7’s could go down to 15rpm (I think).
There is another point – screwcutting. Personal experience is that my minimum speed of 125rpm is much too fast for a short thread which is why I have a mandrel handle and remove the belts when using it. Again, I wonder if 50rpm is too fast for short threads.
In short, I would like to see something, let’s call it a reduction gear, mounted, say at the rear which would enable the speeds to be really dropped. (Perhaps we could call it a “back” gear!)
On a more general theme, I am generally unhappy about the ever-increasing complexity of modern equipment due to the ever-increasing use of electronic control systems as all they seem to do is ensure that if a fault does develop, either the equipment then becomes an expensive door stop, or it becomes necessary to pay someone to diagnose and repair it. Let me give you an example. My car is a 4 year old Ford Focus. Shortly after I bought it at 2 years old, a fault developed such that hard acceleration in the lower gears, eg high engine revs, would cause the engine to start stuttering. My local garage attached a diagnostic unit which agreed there was a fault, but could not go any further. Accordingly the car was sent to a Ford Main Dealer for a full diagnostic at £70, only to find that the problem was the fuel filter at £30. In all probability, 20 years ago, my local garage would have simply changed the filter anyway as there wasn’t much else it could have been, but with electronic controls…..
So, as far as an ideal lathe is concerned, what I would like to see is one which has the choice of electronic and manual controls, electronic for the flexibility electronics offer, but has the option of being able to fall back onto pure manual control for those occasions where manual is thought to be better and for if the electronics fail.
As has been said, electronics are here and are not going to go away, but it does make the device, whatever that device is, more complex, and hence, in my opinion, more likely to fail.
Another idea would be to ensure that the elecronics are an add-on and that there is a publicly known specification for the lathe or whatever, such that any electronic controller could be used provided it’s output matched the specification. This would mean that any faulty electronics could be simply and easily changed for a new and possibly more up to date version.
Peter G. Shaw
