That very light, brown rust / discolouration
Home Forums General Questions That very light, brown rust / discolouration
  • #522515
    Hollowpoint
      @hollowpoint
      Does anyone know a way to remove that very light, brown surface discolouration you tend to get on machine tools? You know the kind im talking about, it looks like rust (probably is) but its perfectly smooth to the touch and steel wool doesn't usually work on it. Sandpaper does work but im hoping for a non abrasive solution?
      Anyone?
      Hollowpoint
        @hollowpoint
        #522526
        Alan Donovan
          @alandonovan54394
          Hi there.
          If I have something that is ‘rusty / discoloured’ that I want to clean up, but not remove metal in the process. I use a worn out ‘green scouring cloth’ (the type used to remove burnt on food from cookware) lubricated with oil and rub the affected area. If it is a stubborn stain I may use a new scourer, but still lubricate it with oil.
          I frequently remove the ‘dirty oil’ and re-oil as I feel the removed rust is probably quite abrasive anyway. It seems to work but does require some ‘elbow grease’.
          Just one suggestion – I am sure other methods will be along in a few minutes.
          Best regards. Alan.
          #522534
          roy entwistle
            @royentwistle24699
            Steel wool or worn emery cloth with oil
            Edited By roy entwistle on 25/01/2021 15:05:12
            #522537
            Brian H
              @brianh50089
              I can recommend Frost Rust Remover. I had a problem the other year when I silver soldered a boiler in the workshop and all steel items developed a brown film on the upper surfaces. I tried some of the frost rust remover and it quickly removed the film but it needed a light polish to make it bright again.
              It then needs a wash in water followed immediately by dewatering fluid such as WD40.
              I have no connection other than as a very satisfied customer.
              Edited By Brian H on 25/01/2021 15:09:42
              #522541
              Mark Rand
                @markrand96270
                It can be oxidised oil. If it is, a strongly alkaline cleaner may remove it.
                #522546
                Ex contributor
                  @mgnbuk
                  We used something like Metal Brite at my last employment for cleaning & brightening machined surfaces on rebuilt machine tools. I'm not certain it was this exact product, but recall the one we used contained phosphoric acid which the SDS for Metal Brite shows too.
                  It was very effective – planed cast iron surfaces came up like freshly machined. The only references I can find are for 25 litre drums, though.
                  Otherwise, on a slightly abrasive note, brick red "extra fine" Scotchbrite pads used with WD 40 (or similar) work well with minimal surface scratching. For stubborn coolant & tramp oil residues, I use DEB Janitol Rapide water based caustic cleaner diluted about 4:1 with water. Apply with a trigger action spay bottle, leave to stand for a few minutes & wipe off with paper towels. Repeat as required on stubborn stains. Being caustic, it takes the shine off painted surfaces & should be used with eye protection & waterproof gloves.
                  Nigel B.
                  #522547
                  old mart
                    @oldmart
                    A solvent based degreaser followed by oiled steel wool would be all I would use, no abrasives.
                    #522567
                    Mick B1
                      @mickb1
                      Scotchbrite or equivalent green scourer – available in rolls from B&Q etc. – with WD 40.
                      In many or most cases, unless the rust really has a hold, you can get back to a bright finish with no detectable metal removal. Happens most winters to the chuck, milling vice, cross- and compound slide top surfaces on my Warco WM250V, but after half-an-hour or so's work you'd never think it'd been there.
                      I think I'd have to live another 2- or 300 years for it to cause any wear to worry about.
                      Edited By Mick B1 on 25/01/2021 17:16:47
                      #522573
                      Breva
                        @breva
                        Not directly what you have asked about but related, I find Lanolin a very effective rust inhibitor during the winter months. IIRC a jar costs about £6 on the Bay and it will last you a lifetime. It is better for tools not in regular use as it is a bit greasy, but a very thin coat is all it takes. It is easily removed and as sold has a pleasant smell.
                        Search for :Dax 100% PURE LANOLIN Super Hair Conditioner
                        #522579
                        Mike Poole
                          @mikepoole82104
                          Removing the brown finish will restart the battle to keep the bright finish. The brown patina tends to be stable whereas a bright finish will immediately want to return to the brown one.
                          #522586
                          Tim Stevens
                            @timstevens64731
                            In the sporting gun world (UK version) a gun which is nicely browned is regarded as 'just right'. No, not a kalashnikov, nothing a Trump wally might flaunt, but a nice black-powder percussion cap twelve bore, of course.
                            Cheers, Tim
                            #522604
                            Hollowpoint
                              @hollowpoint
                              Some interesting food for thought. Might have to give the rust remover a go. Some of my tooling has a nice engine turned type finish, obviously abrasives would spoil the finish.
                              #522615
                              old mart
                                @oldmart
                                Lanolin is used on the Lockheed Hercules C130J propellor hubs. The hubs are sulphuric anodised, but not subsequently painted, but coated in lanolin. Paint might conceal underlying deterioration, and the lanolin gives protection for the hub under the cowling, but can be easily be washed off with solvents for close inspection.
                                Breva's post reminded me of this.
                                Edited By old mart on 25/01/2021 20:13:01
                                #522619
                                Matt Harrington
                                  @mattharrington87221
                                  Lanolin – I was once given a bottle of the stuff and IIRC it was mixed with white spirit. It was used by RR to preserve some parts of an RR jet engine (cant remember what) . I used to use it on my motor bike spokes & rims during winter months. It was brilliant!
                                  Matt
                                  #522621
                                  Pete.
                                    @pete-2
                                    Posted by Tim Stevens on 25/01/2021 18:25:45:
                                    Cheers, Tim
                                    Those Trump wallies are more likely to carry AR15's, a rifle that uses an aluminium alloy receiver and hand guard, most likely modern protection methods on the barrel like cerakote etc, unlikely to have any corrosion issues, this being an engineering forum, might as well make your snide remarks accurate and relevant.
                                    #522649
                                    Paul Lousick
                                      @paullousick59116
                                      Lanolin is now available in spray cans by the makers of WD-40 at the hardware store.
                                      #522651
                                      Brian H
                                        @brianh50089
                                        Lanolin was always used by the MoD to preserve weapons. MANY years ago n the Air Cadets we were supplied with some deactivated Lee Enfield Mk3s which were smothered in lanolin. It took a lot of removing.
                                        #522657
                                        Phil P
                                          @philp
                                          Posted by Paul Lousick on 25/01/2021 22:23:44:
                                          Paul.
                                          I just googled it, looks like it is not available in the UK……..Pity
                                          Phil
                                          #522665
                                          Nigel Graham 2
                                            @nigelgraham2
                                            Lanolin dissolved in white-spirits is an old but effective preservative for wire-rope, especially when such ropes had sisal cores. The rope is soaked in the solution then hung up to drain and dry. Worth considering for trailer-winches, and for winding-ropes on miniature traction-engines & ploughing-engines.
                                            As far as I know lanolin is not only tenacious and long-lasting, but also doesn't carry the skin-health risks inherent with mineral oils.
                                            I tried to investigate gun-blue for protecting the bare steel parts on the tool-&-cutter grinder I am building. My security software blocked my attempts, and so far I have no reply from a major country-sports stockist that lists the stuff but not the weapons, making me wonder if the system stopped its transmission!
                                            Yes I did try "ours" first but it looks as if only Chronos stocks metal-blacking, and then warns it gives no real protection against rusting.
                                            #522679
                                            Danny M2Z
                                              @dannym2z
                                              I have found that Inox MX3 is quite a useful lubricant and metal protector for workshop use. It is lanolin based. More info here Inox and Lanox engineering uses
                                              * danny *
                                              #522712
                                              Gordon A
                                                @gordona
                                                Boiled linseed oil takes a while to dry, but leaves a nice protective coating. I was told by an old gardener many years ago in order to protect garden tools over winter storage in a damp unheated shed, coat the metal bits in boiled linseed oil and the wooden bits in raw linseed oil. It appears to work.
                                                Gordon.
