Test Thread for inserting images
Home Forums New Forum Software questions, comments and Test Threads Test Thread for inserting images
Viewing 25 posts - 51 through 75 (of 83 total)
  • #688642
    John Hinkley
      @johnhinkley26699
      As an experiment, I’m going to try to insert a 3D rotatable pdf image.  If it works you can left-click and drag on part of the picture to change the view.  If it doesn’t accept it, you won’t!
      Well, it didn’t.  It will only accept jpeg, png or gif images, not pdf as we were promised.  Shame.
        PDFs can be stored in your ‘Documents Gallery’
        … might be worth trying that
          As Michael says you can put PDFs XLS and DOC format files into a gallery (set it as a document gallery) and then they can be clicked on if you copy and paste the url into a reply
          The 3D ones can also be uploaded but you will nee dto download and open in say Adobe to get the 3D to work try this one
          As a PDF is not an image file extension it is not unreasonable for a icon marked “insert IMAGE” not to work.
          #688777
          John Hinkley
            @johnhinkley26699
            Thanks, Michael and Jason,
            I’ll try your suggestions and see how I get on.
            ianj
              @ians
              Just a try at inserting a photoPC190708 (Small)
              #688912
              ianj
                @ians
                Just a try at inserting a photo.PC190708 (Small)
                #688917
                peak4
                  @peak4
                  That seemed to work well enough.
                  Just out of curiosity, what size was it before you uploaded it to the site.
                  It’s displaying @ 640×480
                  Also out of curiosity, was it taken on an Olympus?
                  Bill
                  #689518
                  ianj
                    @ians
                    Hi Bill.
                    I resized it from 1600 x 1200 to 854 x 480 before uploading it. It appears twice because I got an error report the first time so tried again, but when I looked the first one had loaded any way!
                    Yes it was taken using a Olympus X-43, how did you know that?
                    Ian
                    #689550
                    Alan Jackson
                      @alanjackson47790
                      PICT0016PICT0010
                      #689750
                      KEITH BEAUMONT
                        @keithbeaumont45476
                        As things are gradually getting better ,I thought it tine to try and load a photoas a diredt drag and drop from my Desktop. Whoops, Onlly the top showing ,unless we scroll down. Are we limited to space allowed?
                        Keith
                        3-DSC04413
                        #689755
                        KEITH BEAUMONT
                          @keithbeaumont45476
                          After the long wait to load ,after pressing the submit button, I get the full photo. I can see this being confusing when trying to load several photos.
                          Keith
                          #689771
                          Jss
                            @jss
                            Latest attempt at posting an image.
                            IMGP0845
                            This is the set up for truing up the top surface of the tee slot in the saddle of my Coronet Major woodworking lathe.
                            Alan Jackson
                              @alanjackson47790
                              I know I should not mention the Home shop Machinist site but they give you the option when you upload a photo of, full size, half size and a small size photo to be inserted with your text.
                              Alan
                              #690008
                              Yngvar F
                                @yngvarf
                                IMG_0077IMG_1049
                                #690304
                                Terry Kirkup
                                  @terrykirkup37827
                                  So does anyone know what the “gallery” option is for? I created one and stuck 3 photos in there, assuming I’d insert them into my post from the gallery as we did from albums, but no sign of any access to do that. Puzzled.
                                  #690307
                                    On Terry Kirkup Said:
                                    So does anyone know what the “gallery” option is for? …
                                    It appears to be somewhere that an opportunist can advertise for free
                                    https://www.model-engineer.co.uk/members/purchaserpk/mediapress/purchaserpk/
                                    Clive Hartland
                                      @clivehartland94829
                                      At long last I have found how to post a reply, I have fumbled my way through the new format slowly.
                                      Not sure I like it to much, lots of indistinct controls like the, ‘Reply button’.
                                      #704789
                                      peak4
                                        @peak4
                                        Sed ut perspiciatis unde omnis iste natus error sit voluptatem accusantium doloremque laudantium, totam rem aperiam, eaque ipsa quae ab illo inventore veritatis et quasi architecto beatae vitae dicta sunt explicabo. Nemo Zoll P3150151_400 ♥ enim ipsam voluptatem quia voluptas sit aspernatur aut  odit aut fugit, sed quia consequuntur magni dolores eos qui ratione voluptatem sequi nesciunt. Neque porro quisquam est, qui dolorem ipsum quia dolor sit amet, consectetur, adipisci velit, sed quia non numquam eius modi tempora incidunt ut labore et dolore magnam aliquam quaerat voluptatem. Ut enim ad minima veniam, quis nostrum exercitationem ullam corporis suscipit laboriosam, nisi ut aliquid ex ea commodi consequatur? Quis autem vel eum iure reprehenderit qui in ea voluptate velit esse quam nihil molestiae consequatur, vel illum qui dolorem eum fugiat quo voluptas nulla pariatur?
                                        Yet another experiment, Now uploaded a 400 pixel wide image, resized it after uploading to about 200, since that now seems to work, and dragged it to a place in the text adjacent to the heart symbol in the preview pane.
                                        Bill
                                        #761783
                                        peak4
                                          @peak4
                                          Just a test, please ignore; This site really needs a “Preview” option before Submit
                                          Direct posting of “BB code” from Flickr into a post
                                          [url=https://flic.kr/p/2kqVnbP][img]https://live.staticflickr.com/65535/50821479247_840061cc7e_b.jpg[/img][/url][url=https://flic.kr/p/2kqVnbP]Slik Sliding Adjustable Spanner[/url] by [url=https://www.flickr.com/photos/peak4/]Bill Williams[/url], on Flickr
                                          Direct posting of “Embed code” from Flickr into a post
                                          Slik Sliding Adjustable Spanner<script async src=”//embedr.flickr.com/assets/client-code.js” charset=”utf-8″></script>
                                          Direct posting of Flickr Share Shortcode
                                          Direct posting of Flickr photo URL (album) from browser address bar
                                          Screenshot of the above in Notepad before the site processes any of the URLs, using Insert Image icon from the top bar and pasting from clipboard on a Windows PC
                                          image_2024-10-29_131626875
                                          Bill
                                          #761789
                                          peak4
                                            @peak4
                                            How Robert’s post displays from the Search option on forums Note the img in square brackets, which some forums demand (but not this one)
                                            image_2024-10-29_132544054
                                            How it displays in a normal thread/topic
                                            image_2024-10-29_132658641
                                            I can’t easily find a way within Flickr to generate the simple img code shortcut, so it displays the same on here.
                                            Unless this does.
                                            BB Code link from Flickr, but inserted as a URL using the link icon, rather than just pasting
                                            http://[url=https://flic.kr/p/2kqVnbP%5D%5Bimg%5Dhttps://live.staticflickr.com/65535/50821479247_840061cc7e_z.jpg%5B/img%5D%5B/url%5D%5Burl=https://flic.kr/p/2kqVnbP%5DSlik Sliding Adjustable Spanner[/url] by [url=https://www.flickr.com/photos/peak4/]Bill Williams[/url], on Flickr
                                            Screenshot of the above before submitting
                                            image_2024-10-29_133119762
                                            #761796
                                            peak4
                                              @peak4
                                              Ah Well second test failed
                                              image_2024-10-29_133312148
                                              #761803
                                                One form Flickr copied and pasted. Flickr images and video always seem to show some odd code at the end.
                                                20241018_095201<script async src=”//embedr.flickr.com/assets/client-code.js” charset=”utf-8″></script>
                                                #761812
                                                peak4
                                                  @peak4
                                                  I think that’s only if you use the “Embed” code link, rather than just the “Share” one, but unfortunately the latter doesn’t allow you to select image size
                                                  image_2024-10-29_141810149
                                                  Using that link, just copy/pasted below
                                                  20241018_095201
                                                  #761816
                                                  peak4
                                                    @peak4
                                                    That’s interesting, Using that “share” link, the image displays smaller on here, though is did have 640 wide selected in both BB & Embed
                                                    Same Share link but with 1024 pre selected in both other options
                                                    20241018_095201
                                                    #761819
                                                    peak4
                                                      @peak4
                                                      and from browser address bar URL, juust copy/paste, not using link button
                                                      20241018_095201
