Tender Top Flare
Tender Top Flare
Home Forums Beginners questions Tender Top Flare
  • #171538
    Malcolm Harvey
      @malcolmharvey97633
      I am building a Titfield Thuderbolt in 3.5" gauge as a first attempt. I am about to start building the tender body. The top of the sides are flared. I know how to make the flare but should I anneal the brass first or not. There seems to be differing opinions on this. I am using 20g brass
      TIA
      Malcolm Harvey
        @malcolmharvey97633
        #171540
          If its one of the softer brasses than you should be OK without as its only a gentle bend. If you do start having to anneal the brass it can put a buckle in the sheet if you are not careful.
          J
