I'm surprised no one has mentioned that the spindle fitting aspects all need to be machined in one setting.
If the tap has a centre hole the tail stock centre can be used to keep it square, just the same as when the face of the tails tock quill is used to keep a die square. A bit of a pain as the tail stock quill has to be withdrawn each time the tap has done a part turn cut and then wound back to break the chip.
I have been known to use a spanner to turn the tap but in that case the tail stock centre must be used to apply pressure so that the tap remains square on. Needs two hands. One on the spanner and the other on the tails stock feed wheel.
Sometimes work still runs true if the chuck holding it is removed from the lathe and then put back on. Easy to check and if so the tapping could be done off the lathe but the tap must be kept square. In training they used to make us check that every 1/3 of a turn with a small square. Once a tap is well in it tends to look after itself but the initial stages are crucial and easy to mess up. ( The end of the stock of a small toolmakers square – the blade was usually to long )
The initial hole in the blank might be drilled off the lathe. Fine but it needs to be bored when it is on the lathe. Same if it's drilled on the lathe.
The best way of finishing to size is to make a complete dummy spindle nose first. It needs to be precisely sized. Threads can be cut with a form tool but if done single point the sums have to be done to produce a flat topped thread with flanks in the correct position and the valleys too deep to account for the use of a pointed tool. It can be tried in another back plate. Ideally one that was made by the lathe manufacturer as they will have used a very precise fit. Measured the threaded portion of the spindle nose will probably be -0.002" max under size and the thread in the back plate very slightly over sized.
Normally the face plate blank would be mounted, faced, drilled, bored and screw cut to suit the dummy nose. Then the register cut. The threading will help keep the dummy nose square as it's screwed in to test the register. The usual answer to an accurate register fit is if it needs to be -0 +001" is to get close and then take 0.0005" cuts till it fits. I'd be hoping for a very slight interference fit which would mean very fine cuts. However if the flanks of the thread are very precise they will tend to centralise things when the back plate is screwed on.
Given no screw cutting I think I would still make a dummy spindle nose but one without the thread just turned down to what ever core diameter is going to be used for the tap and bore for that to fit first. Then tap and then cut the register. If the register is the same size as the thread or as they usually are very slightly smaller there will still be thread marks in the register when that is on size especially when a tap is used or a pointed tool. This can also happen when a form tool is used due to not aligning it precisely. The register is significantly larger on some lathes so that doesn't happen. The marks don't really cause any problems providing it is all accurately made.
There are some comments on making back plates here
They have changed since the last time I looked. Pity on some of them. As mentioned not using cast iron isn't a terribly good idea. It doesn't pick up and stick like mild steel and others can so a very close fitting register is probably not a good idea at all. The comments about the Boxford are interesting. The spindle thread nose is just over 0.0015" under the size of the register on mine. It is possible to make a back plate that appears as he describes and also be a perfect fit. More often there will be signs of the peak of the the thread in the register because the thread depth has had to be increased to account for flank angle errors or maybe the lathe turns a touch of taper. It doesn't take much of an error at all to cause this to happen.
