Taylor Hobson cutter grinder modificaton
Home Forums Workshop Tools and Tooling Taylor Hobson cutter grinder modificaton
Viewing 9 posts - 26 through 34 (of 34 total)
  • #782375
    Andrew Crow
      @andrewcrow91475
      Hi David, I’ve been following this thread since it started and it’s looking really good.
      Great to see something that originally had limited use now being given a new purpose with the ability to grind a wide range of tools.
      Andy
      Martin Johnson 1
        @martinjohnson1
        Looking good, David.
        Just wondering how you are indexing the drill through 180?
        Some time back Jacques Maurel described a cam system of drill & tap grinding in MEW which would be fairly easy to incorporate.  I did it on my home spun grinder and am very impressed with results and ease of use.  Sorry, I dont have the references to hand as I am away from home just now.
        Martin
        #782672
        Bazyle
          @bazyle
          #782725
          David George 1
            @davidgeorge1
            Hi Martin I have put a collar with four equal distant holes in with a grub screw to clamp it in place. These holes locate on a pin in the top slide so I can release  the side clamp lever slide the collet holder back then rotate to opposite hole, slide the collet holder forward to stop and re-clamp and grind the second edge. I can do either two or four for end mills as well and will make a collar for some three flute countersinks I would like to sharpen.
            20250211_070910
            20250211_070901
            David
            #782963
            David George 1
              @davidgeorge1
              I decided to try drilling with the drill which I have just sharpened and it worked perfectly. I didnt even spot or center the hole  and it cut perfectly.
              20250212_170951
              20250212_171044
              20250212_171201
              David
              #785267
              David George 1
                @davidgeorge1
                I managed to do some work on the parts for the tool holder jig. I had to machine a half circular end to the angle bracket so it can be engraved with the angle scale.
                20250223_164309
                20250223_165642
                20250223_190729
                I used arotary table and a 6mm carbide end mill.
                David
                #802919
                David George 1
                  @davidgeorge1
                  I Have got round to continuing with the cutter grinder mod and have made an adjustable table so I can grind flat tooling like turning tools tips etc.
                  20250613_091304
                  Also I have engraved the dials so I can use them for seting and amount grinding angles etc. I have also started making base for the grinder as it is a bit light and wobbly.
                  20250614_161935
                  20250614_161853
                  David
                  #806524
                  David George 1
                    @davidgeorge1
                    I have mostly finnished the mods to the grinder I intend when finnished to have it chemicaly blacked and the engraving filled whith white paint to show up the lines and digits. I  thought I would actualy sharpen an end mill and after changing the adiamond wheel for a white Aloxite 100 grit wheel and stet up and easily sharpened the 20mm cutter.
                    20250708_153143
                    20250708_161351
                    David
                    #806547
                    Bazyle
                      @bazyle
                      You have graduated the horizontal axis – do you have plans for the vertical? The Worden seems to make a major feature of it.
