Taylor Hobson cutter grinder modificaton
Home Forums Workshop Tools and Tooling Taylor Hobson cutter grinder modificaton
Viewing 13 posts - 26 through 38 (of 38 total)
  • #782375
    Andrew Crow
      @andrewcrow91475
      Hi David, I’ve been following this thread since it started and it’s looking really good.
      Great to see something that originally had limited use now being given a new purpose with the ability to grind a wide range of tools.
      Andy
      Martin Johnson 1
        @martinjohnson1
        Looking good, David.
        Just wondering how you are indexing the drill through 180?
        Some time back Jacques Maurel described a cam system of drill & tap grinding in MEW which would be fairly easy to incorporate.  I did it on my home spun grinder and am very impressed with results and ease of use.  Sorry, I dont have the references to hand as I am away from home just now.
        Martin
        #782672
        Bazyle
          @bazyle
          #782725
          David George 1
            @davidgeorge1
            Hi Martin I have put a collar with four equal distant holes in with a grub screw to clamp it in place. These holes locate on a pin in the top slide so I can release  the side clamp lever slide the collet holder back then rotate to opposite hole, slide the collet holder forward to stop and re-clamp and grind the second edge. I can do either two or four for end mills as well and will make a collar for some three flute countersinks I would like to sharpen.
            20250211_070910
            20250211_070901
            David
            #782963
            David George 1
              @davidgeorge1
              I decided to try drilling with the drill which I have just sharpened and it worked perfectly. I didnt even spot or center the hole  and it cut perfectly.
              20250212_170951
              20250212_171044
              20250212_171201
              David
              #785267
              David George 1
                @davidgeorge1
                I managed to do some work on the parts for the tool holder jig. I had to machine a half circular end to the angle bracket so it can be engraved with the angle scale.
                20250223_164309
                20250223_165642
                20250223_190729
                I used arotary table and a 6mm carbide end mill.
                David
                #802919
                David George 1
                  @davidgeorge1
                  I Have got round to continuing with the cutter grinder mod and have made an adjustable table so I can grind flat tooling like turning tools tips etc.
                  20250613_091304
                  Also I have engraved the dials so I can use them for seting and amount grinding angles etc. I have also started making base for the grinder as it is a bit light and wobbly.
                  20250614_161935
                  20250614_161853
                  David
                  #806524
                  David George 1
                    @davidgeorge1
                    I have mostly finnished the mods to the grinder I intend when finnished to have it chemicaly blacked and the engraving filled whith white paint to show up the lines and digits. I  thought I would actualy sharpen an end mill and after changing the adiamond wheel for a white Aloxite 100 grit wheel and stet up and easily sharpened the 20mm cutter.
                    20250708_153143
                    20250708_161351
                    David
                    #806547
                    Bazyle
                      @bazyle
                      You have graduated the horizontal axis – do you have plans for the vertical? The Worden seems to make a major feature of it.
                      #807895
                      David George 1
                        @davidgeorge1
                        I have got round to the vertical height adjustment with a serice of interlocking spacers of various thickness.  For most flat jobs the centerline is the same as the center of the grinding wheel but for some end mill cutters etc the angle needs height adjustment and I have a series to adjust that.
                        20250719_172938
                        20250719_172953
                        The spacers interlock with the bed location and the base of the angle plate holder so the radial angle can be set to suit the end of the cutter etc.
                        David
                        #807897
                          It gets better all the time, David
                          David George 1
                            @davidgeorge1
                            I have received the parts back from blackerising and it looks great to me after filling the engraving for the dials and angle indicators.
                            20250822_140449
                            20250822_140518
                            #813544
                            David George 1
                              @davidgeorge1
                              20250822_153210
                              20250822_151809
                              Thats it done know I think.
                              David
