Taps and dies
Taps and dies
Home Forums Beginners questions Taps and dies
  • #6724
    rebekah anderson
      @rebekahanderson95322
      #120637
      rebekah anderson
        Hiya guys,
        Another question for yah.
        I have been trying to cut a left ahnd thread. Its M3 size.
        I turn a bar down to 3mm then cut the thread using a M3 LH. Once i have a good cut i then try and screw it into the female LH thread hole. However it just zips in, no screw required. Obviously not the desired effect. I measured the outer diameter and find that it's 2.5 mm. Again undesirable.
        I have cut a normal RH thread doing exactly the same with the correct result.
        So I am thinking i have been sold a duff LH die that isn't M3 size.
        Would I be correct in my fury or am I being mince and missed something out?
        Cheers
        Becky
        #120642
        Chris Heapy
          @chrisheapy71135
          Possibly. Is the die a split-die (i.e., adjustable)? If so, it may be you have tightened it within its holder to the extreme minimum size. There are 3 screws in the holder (normally), and when you tighten the center one it wedges the die open making it cut a larger diameter thread, the two screws either side just lock it to the desired cutting size and prevent it springing open further.
          #120649
          David Jupp
            @davidjupp51506
            The size will usually be marked on one face of the die. Should allow a quick check.
            #120650
            rebekah anderson
              I may be a bit blond but not that much lmao.
              Yes it does say M3 LH lol
              #120651
              Springbok
                @springbok
                Rebekah,
                Use firstly the centre screw only, use cutting oil, check what is stamped/engraved on the die, gently clean up the cut with a VERY fine abrasive once again useing cutting oil, Now loosen centre screw and lightly tighten other 2 then centre, go for 2nd cut then once again clean up.
                I am presuming that you have a nut to check tollerances.
                good luck (I usualy need it)
                Bob
                #120662
                MICHAEL WILLIAMS
                  @michaelwilliams41215
                  A common mistake is to turn the die the wrong way when doing LH threads . Under end load it will still cut but more like a hollow milling cutter than a die – basically reduces bar to core diameter .
                  MikeW
                  #120673
                  Ian S C
                    @iansc
                    You could check the size by putting the shank of a tapping size drill through the die, if it's a split die, it will proberbly need opening. Ian S C
                    Edited By Ian S C on 26/05/2013 12:58:17
                    #120763
                    rebekah anderson
                      Ian,
                      you are correct. Although opening isn't easy. Lol
                      #120775
                      colin hawes
                        @colinhawes85982
                        You may need to turn the dia. to about 2 thou undersize to get a clean thread. There are some poor quality dies about that will never be capable of cutting on a full diameter. Colin
