Posted by David Standing 1 on 05/01/2018 15:41:29:
Posted by Howard Lewis on 05/01/2018 15:38:47:.
But, the question is, what IS High Quality Steel, and how does it relate to HSS?
I think the confusion arises on the assumption that HQSS is a particular steel. I don't think it is. High Quality Special Steel refers to the way it's made rather than what's in it.
HSS is a family of steel alloys containing Tungsten, Cobalt and Molybdenum. One way of making HSS is to mix the metals up in a furnace and pour it into ingots from which tools are made later. Nothing particularly special about the process and it comes with the risk of inclusions in the steel that might spoil a tool made from it.
It's possible to do better. An HSS could also be an HQSS. The differences in manufacture that might make HSS 'High Quality and Special' could include one or more of :
- The alloy made from specially purified base metals.
- A specially clean furnace, probably electric, with the entire production process designed to minimise contamination. This might include melting in Argon rather than Air and other elaborate measures.
- Improving the mix by applying a micro-alloying technique.
- Increasing the physical consistency of the alloy by sintering compressed powder rather than simply allowing a melt to cool.
- After manufacture, a complicated heat treatment optimised to improve the material.
- Application of a rigorous quality process throughout.
As might be expected, an HQSS will be more expensive than the ordinary product, perhaps much more expensive.
One interesting possibility is scrap HQSS ending up in your junk box. Depending which one it is machining could be an absolute nightmare! Apparently the Boron Steel sometimes used in car safety structures is tough enough to defeat the giant hydraulic cutters used to rescue crash victims. Trying to turn it in your lathe would be seriously disappointing!
Edited By SillyOldDuffer on 05/01/2018 17:50:49
