Tapping stainless
Tapping stainless
Home Forums The Tea Room Tapping stainless
  • #35930
    david gregg 1
      @davidgregg1
      david gregg 1
        @davidgregg1
        I have just finished tapping 75 m4 blind holes in 12 mm square 316 stainless steel , this was a job for a local wholesale butcher who was unable to get these spare parts because off the present lock down .It was a nerve wrecking business as I had no spare material and there would be no chance of removing the broken tap .I drilled the holes 3.4 mm this is .1 over the recommend size but it certainly worked for I also used a spiral flute tap which is recommend for stainless ,but I think after 75 holes it is getting slightly harder to tap
        #475743
        Clive Foster
          @clivefoster55965
          david
          I'm now a fan of serial type taps for this, and frankly, most other sorts of thing. Noticiably easier to turn so, presumably, less likely to gall up and break.
          I get mine via E-Bay from davethetools. Vokel brand and recommended for stainless steel.
          #475744
          Mick B1
            @mickb1
            Spiral flute taps are brilliant for blind holes – the way they hook the swarf out seems almost miraculous. But I've only used them on aluminium alloy – I'd think stainless could present challenges. Sounds like you did a cute job.
            #475905
            old mart
              @oldmart
              What lubricant did you use?
              #475914
              jimmy b
                @jimmyb
                I tap and die a lot of 304 stainless (mainly M6). I use Rocol RTD liquid, I've tried loads of other cutting oils, but none work as well on stainless.
                Jim
