What sort of motor, how big, and what sort of electronic control?
If a DC Motor in the 500W to 1500W range, PWM controlled as fitted to a mini-lathe up to some large hobby mills, then no starter is needed. Except make sure the operator knows to stop by winding speed down and never to start with the speed control at high. (The operator is the starter!)
If a 3-phase motor with a VFD, then the VFD can be configured to accelerate, decelerate, and detect over-current, So in addition to controlling speed, VFDs are also excellent for managing start surges. It seems most modern VFDs come pre-set with reasonable surge parameters, otherwise read the horrible manual!
Single-phase motors briefly draw an exceptionally heavy current when starting. Big ones, say more than 1kW, need a starter, either electromechanical or electronic. (Given the choice, avoid single-phase motors.)
Similarly, big 3-phase motors connected to a 3-phase supply also need a starter. These days it's becoming common to fit a 3-phase to 3-phase VFD because of the extra control they give compared with an electromechanical starter.
Often as not the motors on small machines don't have starters because the supply can handle the surge. It may be necessary to help with a slow-blow fuse or a suitable trip – if so, the machine's manual should have all the details.
PS Just read other replies which focus on transient protection, i.e. voltage spikes that might upset the electronics. If that's the issue, the power leads sold for computers will do the job. They vary in sophistication from cheap and simple (effective for mild problems), more expensive for more difficult cases, up to serious money for a professional box sold by RS and others. What's the problem? Kit in your workshop, or coming in from outside?
Edited By SillyOldDuffer on 22/03/2020 17:14:40
