supercharged V12 2 stroke
Home Forums I/C Engines supercharged V12 2 stroke
  • This topic has 274 replies, 55 voices, and was last updated 4 May 2025 at 08:10 by Michael Gilligan.
Viewing 25 posts - 201 through 225 (of 275 total)
  • #240476
    not done it yet
      @notdoneityet
      As a recent new member I haven't followed this thread before. I was amused about the 'discussion' of superchargers, turbos etc., because large, slow running marine engines of this type have been around for a loong time. Even high revving diesels heve been in use for around 70 years (3000rpm Detroit diesels as fitted in trucks and tractors, per eg). Everyone should know that they need crankcase compression (in the case of motorcycle engines, per eg) or a forced (blower) feed for others, such as the detroits. The detroits have a poppet valve for exhaust, so are probably easier to turbocharge as well as being blown. The difference is that any turbo engine of that type still needs a blower – turbos give no bost until spooled up whereas Rootes type blowers are positive displacement machines. One reason why the blower speed has to be in a fixed ratio to the engine speed in these old engines. Modern electronically controlled fuel pumps can more easily control the injection fuel/ratio, but most of these Detroits in 'pulling tractors' just inject soo much excess fuel that they smoke more than the proverbial train.
      Anyway, I will now go back and read this interesting build. Very well done, Dean. I doubt iwould ever make one as complex as that. A veritable masterpiece. Do you intend flying it? How much power are you expecting?
      dean clarke 2
        @deanclarke2
        Hi Richard, yes I am still planning on flying a V12 but probably not this exact one as I have already started devolpment on a mk2 version with some fairly major modifications and design alterations, expected power output is about the 10 hp mark with the rev top end somewhere between 12k and 15k, I guess time will be the ultimate judge of these expectations. as for the current project work commitments have limited time but I have been able to progress the project a little bit. Below is an update on the new starter and also the new carb and manifold which I have made as 1 unit eliminating and separate manifold unit.
        all thats left for this bit is a bit of cosmetic profiling and they should be ready for some barrels and bits, lol.
        Thats all for now I'm afraid
        cheers
        Dean
        Edited By dean clarke 2 on 19/06/2016 06:54:00
        #248747
        dean clarke 2
          @deanclarke2
          Well at last a bit more to share on this V 12 build project. Sorry for the extended delay in updates but been overly busy with other life demands recently. Here are a few photos showing what I've been up to in recent weeks with this engine build and the related side projects. The anodizing plant is moving ahead slowly and I have finally finished the new starter. photos below show progress to date
          Currently working on the remaining parts for the anodizing plant and will post the photos as soon as I can..
          here's the finished starter.
          So now all I need to do is get the damn anodizing plant all done and put the engine back together and start it up again. YAY getting there slowly………. but surely thankfully.
          Cheers for now
          Dean
          #257854
          dean clarke 2
            @deanclarke2
            Well after much ado about nothing here I am again with another update, finally! having plucked up the courage to give this anodizing lark a go I found it wasn't actually so hard after all.Not sure why I was so chicken about doing it, just nervous of the unknown probably, oh and the risk of ruining irreplacable parts maybee. Right so now that i have faced my fears the photos below show the progress to date. here's the results of the first test run.
            not too bad an effort me thinks……… so onwards we go….. here's the anodizing bath in action doing the first run of the v12 fin blocks and heads.
            I had originally set up to do all the parts at the same time but found that the load was way too high for the power supply to cope with requiring more than 15 amps to run and as the power supply is only rated to 15 amps max it just wasn't going to work. The solution was to just downsize the parts stack to both fin blocks and heads as the parts are mated together and had to be the same colour. even then I had to drop the voltage to 10 volts and keep watch on it as the overload would trip out every 10/ 15 mins or so and needed to be reset. this was less than ideal in theory but seems to have worked out ok in practice as the parts came out perfectly barring a small blemish where the colour didn't take up, I suspect because the cleaning stage wasn't good enough. Oh well. photo below shows the first parts run fresh out of the bath.
            A very nice even colour and finish so on with the next bits, drive belt housing and cover.
            These parts didn't quite go as planned and were a very dissapointing result. It looks like they anodized ok but they didn't appear to take up any colour. These were the only failure of the day and were also the only parts that were sandblasted in finish so I'm not sure if that was the cause or weather it is something else, anyone got any bright intelligent ideas? below is a photo showing all the parts that were done including the test parts, not a bad days effort I reckon but there's still a few questions that need answers.
            Cheers for now
            Dean
            Edited By dean clarke 2 on 25/09/2016 19:19:58
            #257871
              Look good Dean, I was talking to another engine builder at the MEX show last week and he said that he was going to have to sand down some parts that he had blasted as the finish would not take due to lack of an oxide layer.
              #258545
              dean clarke 2
                @deanclarke2
                Well I have managed to start the reassembling process of the v12, starting to look rather loverly me thinks, so here's the latest photos of progress.
                I reckon this looks preeetttyyy mean lol
                Busy stripping the blower drive case and cover ready for re anodizing at the moment along with cleaning up some other bits and pieces to do another anodizing run this weekend. I will endeavour to post photos when i'm all done.
                cheers for now
                Dean
                #258549
                V8Eng
                  @v8eng
                  Superb! smiley
                  #258565
                  Vic
                    @vic
                    Very nice work Dean! yes
                    #258646
                    John Olsen
                      @johnolsen79199
                      I saw this in the flesh last night, it looks even better than the photos.
                      dean clarke 2
                        @deanclarke2
                        Hey there, me again and it's only been a couple of days, guess the wife is away, lol……… anyway I've been up to more mischief in the shed this weekend and have been able to do the re-anodizing of the blower drive case and cover. While they aren't perfect I think that they've come out quite well. Photos below…………………
                        Doesn't look to shabby I reckon, not bad for an amateur anyway. So feeling quite encouraged by the good results I had a go at anodizing some other stuff, unrelated to the v12 but interesting none the less..
                        Ones dark blue and the other violet, nice good even colouring and no missed spots so I'm getting better at it. the blue heads and fins are actually the same colour but the lighting shows them different for some reason.
                        All in all a very pleasing weekends work………. now what else can I colour in???
                        Cheers for now
                        Dean
                        #258775
                        doubletop
                          @doubletop
                          Dean
                          Love the anodising your results may entice others to give it a go.
                          I've been meaning to comment on the starter. Have you used it yet? I did something similar for my bobcat but couldn't get it to work the load imposed by pushing the starter into the starter dog and the kick when the engine fired and pushed the starter out of the dog caused the engine to stall. maybe not a problem when you've got 12 cylinders. My solution was a sprag clutch bearing in a unit purchased from Hobby King. It’s for starting large scale helicopters.
                          It made starting so much easier
                          Pete
                          #258786
                          dean clarke 2
                            @deanclarke2
                            Hey Pete, how's it going mate? the starter works great in the test setup but haven't got the v12 ready to run yet so can't answer your question, still working on the new carbs. It should be fine though as the lead-out on the dog drive is quite gentle and when the engine fires up I just pull the starter out with it still running so there's no significant loading on the engine at disengagement. will let you know how I get onn when the time comes to bring it back to life.
                            Thanks for all the encouragement guys I really appreciate it.
                            cheers for now
                            Dean
                            #258787
                            Hopper
                              @hopper
                              The intricacy of your work is just astounding. Beautiful result. Thanks for sharing.
                              The anodizing was worth the agonizing, it looks brilliant.
                              #266666
                              dean clarke 2
                                @deanclarke2
                                Hi all, been a little while I know but here is a bit more of the happenings from the workshop. Have finished the new carb bodies and intake trumpets, photos below….new carbs 1.jpg
                                Cheers for now
                                Dean
                                #266672
                                Bill Pudney
                                  @billpudney37759
                                  Absolutely stunning!!!
                                  cheers
                                  Bill
                                  #269281
                                  dean clarke 2
                                    @deanclarke2
                                    Well we have some more progress, albeit slow so slow…………….. I have got the new ignition loom sorted and fitted, looks a bit more like the real thing I reckon………….. photo below, next is to finish the new carbs and fuel rail then it's startup time yay…….. only been far toooo long. oh well.
                                    cheers for now
                                    Dean
                                    #269291
                                    not done it yet
                                      @notdoneityet
                                      Carbs? Look deserving of multi point fuel injection, to mesmiley
                                      If they don't make anything suitable, I reckon you could build your own!
                                      Keep up the excellent work. I am just one of those eagerly awaiting further progress on this amazing project!!
                                      #269760
                                      dean clarke 2
                                        @deanclarke2
                                        So here's the next step in the addition of new bigger and better breathing carbs…….. photo's show the progress to date……
                                        Next it's barrels and levers and we're all ready for start up….
                                        cheers
                                        Dean
                                        #269766
                                        Jeff Dayman
                                          @jeffdayman43397
                                          Looking great Dean, really like the new carbs. Good luck with barrels etc and do please let us see/hear a video when there's fresh noise. JD
                                          #269874
                                          dean clarke 2
                                            @deanclarke2
                                            Ok so I thought I might just put this photo up to show the difference in the cab throat diameters….
                                            hopefully this cures the breathing restriction problem!!!!!!!!!
                                            LOL
                                            Cheers
                                            Dean
                                            #270189
                                            David Taylor
                                              @davidtaylor63402
                                              Wow, that's beautiful!
                                              #270192
                                              V8Eng
                                                @v8eng
                                                Lovely work.
                                                I think you are just a bit late for submissions to the "Turner Prize".smiley
                                                #272493
                                                dean clarke 2
                                                  @deanclarke2
                                                  LOL, probably just as well coz I can't get the damn thing to run now!!!!teethteethcrying 2crying 2angry 2fistkuloucrook………………………………………………………………………………………………It fires up with a squirt of fuel down the throat but wont actually start and run, have spent a few hours messing about with different bits and pieces but gave up in the endangry 2crying 2crying 2, the prime tells me its short on fuel so following that up with some problem solving bourbons and will probably try again next weekend after I stop crying and wailing…… Oh and did I mention that the starter seized solid just to really test the limits of human rage!!!!!
                                                  Wondering if I shouldn't just give up????…………….. except I'm far to stubborn for that..
                                                  Disappointed dean
                                                  #272496
                                                    Posted by dean clarke 2 on 18/12/2016 09:12:22:
                                                    … so following that up with some problem solving bourbons
                                                    Presumably of the Kentucky variety, not these: **LINK**
                                                    https://en.m.wikipedia.org/wiki/Bourbon_biscuit
                                                    Best of luck with it, Dean … it's beautiful piece of work.
                                                    #272497
                                                    Russ B
                                                      @russb
                                                      I know nothing about model engine carbs but if i recall correctly, larger carbs on my race bike, had larger jets because the air velocity was lower so it didn't draw fuel as well – it was much more difficult to get it starting and running smooth at the bottom end with bigger carbs, but it gave it the breathing capacity at the top end.
                                                      Edited By Russ B on 18/12/2016 09:44:48
                                                    Home Forums I/C Engines Topics
