Sump Plug
Sump Plug
Home › Forums › General Questions › Sump Plug
  • This topic has 30 replies, 24 voices, and was last updated 9 May 2019 at 10:46 by David George 1.
Viewing 6 posts - 26 through 31 (of 31 total)
  • #408097
    Ian Usmar
      @ianusmar79339
      Many thanks for all your responses. I have had a look and it fits nicely into the back of a 3/8 Socket so now all I need as bolt and a few nuts to fit the said socket then another socket etc. on the other end. Bobs your Uncle fanny's your aunt. Hopefully. I sprayed with release oils yesterday and it looked like it went into the thread?
      #408101
      Howard Lewis
        @howardlewis46836
        If a 3/8 drive fits over it, can you get a 3/8 drive socket for a 3/8 square?
        Or if you use a reversed socket, rather than use a bolt and nuts (which may slip on it ) why not use a short piece of hexagon bar? To avoid the need for a second same size socket, take a larger piece of hexagon and and reduce one end for long enough to engage fully into another socket to fit?
        If you can use an impact driver, that may provide the shock need to break the threads loose. Once moved, it ought to be easier to continue unscrewing the plug.
        #408107
        Brian Wood
          @brianwood45127
          I might be tempted to make a square headed socket a short distance away from the end in a piece of 30 mm flat strip having some thickness about it and keep that in the toolbox for when it is needed next time.
          A snug fit on the square head of the plug and a thump on the far end with a hammer should shift it with ease in the future.
          #408297
          Phil Whitley
            @philwhitley94135
            Had this problem on occasion, as a last resort, drill a snug fitting hole in the end of a piece of stout flat bar, place over the square, and mig weld it onto the plug. The heat from the welding will expand the whole shebang, and out it will come, fit a new sump plug, preferably something with a hex head!
            #408331
            vintage engineer
              @vintageengineer
              Ordinary 12 point sockets will fit square heads.
              #408374
              David George 1
                @davidgeorge1
                Ian Did you get the sump plug out !
                David
