Posted by Andrew Johnston on 29/05/2017 08:57:59:
Posted by SillyOldDuffer on 28/05/2017 21:24:06:
My lathe only has a 1500W motor. Using the calculator, I worked out that the maximum DOC I should attempt in steel with 1200 rpm feeding at 0.14mm per revolution is about 1.4mm.
So it seems possible that the 1500W motor is not producing 1500W at the spindle. GIven it's driven by a VFD I'd sugest it is runnig below base speed?
Correct. The top speed is 2500 rpm and I'm running the spindle at 1200rpm in these tests. I don't know what the relationship between power, torque and rpm is on this machine / VFD combination is.
Certainly there's less than 1500W at the spindle, perhaps much less. I'd guess the self-act uses a fair proportion of the available power. Also, apart from the VFD/Motor's unknown electrical efficiency, there's plenty of friction. Two belt drives, compound reduction gears in the banjo, a headstock gearbox, a drive shaft, saddle gears, and various bearings are all soaking up power.
Measuring what's available at a lathe's spindle might be an interesting dynamometer project.
