Stevensons collet Blocks.
Home › Forums › General Questions › Stevensons collet Blocks.
  • #157331
    Chris Denton
      @chrisdenton53037
      About to order some of these:
      http://www.arceurotrade.co.uk/Catalogue/Collets/ER-Collet-Fixtures
      Just wondering when you would use the hexagonal instead of the square?
      When in a 3 jaw chuck?
      #23397
      Chris Denton
        @chrisdenton53037
        #157332
        Clive Foster
          @clivefoster55965
          Milling nuts and bolt heads are the main use for me. OK mine are 5c bought way back when but principle is same.
          #157334
          GaryM
            @garym
            Posted by Chris Denton on 07/07/2014 23:28:13:
            ….Just wondering when you would use the hexagonal instead of the square?
            When you want to put six sides on something rather than four?
            wink
            Sorry.
            Gary
            #157339
            Les Jones 1
              @lesjones1
              Hi Chris,
              I bought the hexagonal one to use for sharpening 6 flute milling cutters. As others have said you could use them as a quick way drilling 3 or 6 holes around something.
              Les.
              #157343
                Use with a V-block and the six-sided block can be used to mill 12 facets. I bet even John S. hasn't worked that one out
                Frank.N Storm
                  @frank-nstorm18349
                  Might be a good idea to point out to Chris that the idea behind these fixtures is for using them on a mill, not as cheap collet holder in a lathe chuck.
                  Regards, Frank
                  #157391
                  Chris Denton
                    @chrisdenton53037
                    I didn't think of turning them!
                    I usually use an indexer.
                    Yes I would use it for holding round things on the milling machine.
