Starter/Stock pack of metal bar.
Home Forums Beginners questions Starter/Stock pack of metal bar.
  • #9233
    Ron Laden
      @ronladen17547
      Ron Laden
        @ronladen17547
        Is it possible to purchase a stock/starter pack of round bar, ideally a mix of alu, steel and brass, short lengths say 6 or 12 inches.
        Just wondered if any supplier does this.
        Ron
        #359295
        Paul Lousick
          @paullousick59116
          Ron,
          I have not seen a "starter pack" of metal bars. When I first set up my home workshop, I bought a selection of different size steels and still have some of them. (Never had a use for some sizes after 5 years and a waste of money). It is better to buy the sections that you need for a project as you need them. But if I need some 25×5 flat bar x 200 long, (as an example). I will buy 1 or 2 meters and keep the remainder as stock, knowing that it is a size that I use.
          Metal supplers often have off-cuts which are sold at a reduced price. Also second hand steel merchants and ebay are a source of cheap materials.
          Paul.
          #359298
          Jez
            @jez
            GLR Kennions sell packs – not mixes of metals though:
            https://www.glrkennions.co.uk/budget-packs.html
            I've bought them in the past and been satisfied…
            Jez.
            #359301
              Noggin End will also sell pack of various diameters of one particular metal, just click on each metal and the bundles will come up at the end of each type
              #359302
              Frances IoM
                @francesiom58905
                Is there not a nearby model engineering society you could join ?
                Other members may be able to supply you with small lengths while you get started and recommend sources of material – however you will soon need a small bandsaw (eg the cheapie sold by Chester tools (+ others) this will allow you to buy longer lengths of stock sizes eg 3m length of say 1″, .75″ and 0.5″ round + square bar (free cutting EN1 at least at my small supplier seems more readily available in old imperial sizes) – if you buy eg ?100 worth of metal + collect yourself they will usually chop into 1.5m length easily carried in a car – work out what flat stock you want for a project and buy this at same time – buying very short lengths + the high postage cost is generally not a good idea unless you know exactly what you want it for – again locally steel is cheaper than ali but that may well be what the yard supplies most of – brass is even more expensive.
                Edited By Frances IoM on 24/06/2018 13:37:22
                Edited By Frances IoM on 24/06/2018 13:37:44
                #359303
                David Standing 1
                  @davidstanding1
                  There are loads and loads of suppliers on eBay, such as this:
                  Phil Stevenson
                    @philstevenson54758
                    Mallard Metal Packs http://www.mallardmetals.co.uk/
                    He sells single material packs – see his catalogue – but Rob (think that's his name) made me up a mixed bundle when I started. Different materials, profiles, etc.
                    He was very helpful, plenty of advice.
