squeak, squeal and chatter
Home Forums Beginners questions squeak, squeal and chatter
Viewing 15 posts - 1 through 15 (of 15 total)
  • #6593
    Lloyd Bowers
      @lloydbowers78291
      Lloyd Bowers
        @lloydbowers78291
        Am i right in thinking these are general the same thing first, squeak/squeal is chattering? or are they different,
        Im getting a squealing squeaky noice sometimes (tends to be when lightly cutting) while trying to cut a grove with a 3.5mm tip grove/parting tool. Ive centralised the tool. kept it sharp.
        I dont want to cut too quickly/heavy as im taking my time and also dont want to a jam and damage my workpiece or tool.
        is there something im missing to not doing right, or is it ok while cutting slowly?
        Am i right in thinking it will squeak because its sliding against the surface of the workpiece with not enough preasure or should i be using cutting fluid to stop this, will the squeal cause any problems (apart for annoying anyone close?)
        cheers
        #113031
        KWIL
          @kwil
          What are you cutting, what diameter and at what speed?
          #113036
          Lloyd Bowers
            @lloydbowers78291
            Posted by KWIL on 25/02/2013 09:18:53:
            im cutting an ofcut of steel, which is 18mm down to about 5mm.
            speed….slowest (which isnt that slow) on my exe 3.5 super. i know thats not much help but i dont reall know the RPM. i have a 50mm pully of my motor turing at a guess 150mm. you could probably guess or guage it better from my pic's.
            I guess thats one thing i should really know and work out. motor RPM and ratio's of pulleys.
            thanks for your reply.
            Edited By Lloyd Bowers on 25/02/2013 10:05:57
            Edited By Lloyd Bowers on 25/02/2013 10:06:17
            #113037
              I'd say its a high frequency chatter that sounds like a squeel, 3.5mm wide tip is asking quite a lot of that machine can you not use something narrower and take two bites or keep the load on teh cutter and feed constant
              J
              Edited By JasonB on 25/02/2013 10:20:11
              #113038
              Anonymous
                Posted by Lloyd Bowers on 25/02/2013 09:03:15:
                Same result but different causes. Chatter is a low frequency effect caused by the tool/workpiece/machine not being stiff enough and causing vibration. Chatter normally leaves an regular pattern of marks on the work. Squealing is a higher frequency effect normally caused by the tool intermittently rubbing and cutting rather than cutting cleanly.
                I would say that your squealing is almost certainly caused by too low a feedrate. My standard parting tool is 3mm wide and I use an absolute minimum feedate of 4 thou/rev. One of the 'secrets' to successful parting or grooving is to keep the feedrate up; no half measures.
                Edited By Andrew Johnston on 25/02/2013 10:15:07
                #113041
                Lloyd Bowers
                  @lloydbowers78291
                  ok cheers, i guess feeding too fast and it jams, so get a nice inbetween? just enough to stop the squeeling?
                  will it cause any damage squeeling?
                  Ive tried a 1/8th parting tool (blade and holder) which did the same but again i am taking it easy, so maybe feed a bit quicker. – i notice that sometimes the 1/8th did start to wobble left/right and causing a slanted cut, could that also be too lean on feed speed?
                  #113042
                  Ady1
                    @ady1
                    A great deal has already been said on this subject
                    Do a ME search for "parting" and "parting off"
                    Edited By Ady1 on 25/02/2013 10:57:10
                    #113056
                    Trevor Wright
                      @trevorwright62541
                      Lloyd,
                      Have always parted off by hand feeding, you get a feel for the cut throught he handwheel.
                      Squealing usually occurs when the workpiece is spinning too fast – chatter when parting will usually wake the neighbours and look like a ploughed field…..
                      Keep the revs down, lots of lube (WD40 works well) and try hand feeding.
                      Trevor
                      #113058
                      Russell Eberhardt
                        @russelleberhardt48058
                        The pulley diameters you quote will give about 1500 rpm. OK for turning 18 mm but I would want to reduce the speed to about 1/4 of that for parting, especially on a small lathe. Yes a thinner blade should help – half the width = half the cutting force.
                        Russell.
                        #113060
                        Lloyd Bowers
                          @lloydbowers78291
                          ok, thank you all, ill have to look at larger pulleys, or a back pulley system to lower the rpm. I only have hand feed, will try a few things and wd40..
                          thanks
                          #113067
                          Anonymous
                            Russell: I'm not sure how you arrive at 1500rpm? If I read the OP's post correctly he has a 50mm pulley on the motor driving a 150mm pulley, so a reduction ratio of 3. For a 2 pole motor running at nearly 3000rpm (in the UK) that gives 1000rpm at the spindle, for a 4 pole motor running at 1500rpm that gives 500rpm at the spindle.
                            Addendum: looking at the OP's pictures I'd guess the reduction ratio is a bit more than 3 to 1.
                            #113069
                            Russell Eberhardt
                              Posted by Andrew Johnston on 25/02/2013 15:05:26:
                              Sorry, finger trouble again. I meant 500 rpm of course.
                              Russell.
                              #113073
                              Brian Wood
                                @brianwood45127
                                Hello Lloyd,
                                Are we all missing something obvious? If tailstock support is in use on a hard centre, could the squeal be coming from that? It would vary with load and maybe more when lightly loaded.
                                Just a thought
                                #113095
                                Lloyd Bowers
                                  @lloydbowers78291
                                  well that was better, having some confidence and using wd40 it was loads better.
                                  thanks all. again!
