Sprayer for WD40
Sprayer for WD40
Home › Forums › General Questions › Sprayer for WD40
  • #749600
    Phil Boyland
      @philboyland37326
      Was wondering, does anyone have a recommendation for a simple sprayer that can handle WD40 reliably. I have tried cheapo garden ones and they die after a few days. A quick search has thrown up some pricier ones that can supposedly be used with solvent, but not convinced.
      I bought a gallon of the stuff and although it did come with a sprayer, it wasn’t great and eventually broke.
      #749616
      Baz
        @baz89810
        Garden centre ones seem to work ok for me, I have got a couple of them that must be at least ten years old and work every time. One has W40 in it and the other has Duck oil.
        #749617
        bernard towers
          @bernardtowers37738
          Had the WD from H & Workshop with genuineWD40 sprayer thrown in, absolutely B****y useless and have tried others with the same result and now use old RTD bottle with FINE tube fitted. MAGIC
          #749632
          not done it yet
            @notdoneityet
            I was given a bulk WD40 container, along with a WD40 spray bottle.  It has been totally reliable so far.
            #749637
            Wink Hackman
              @winkhackman25989
              Try the Wurth ones.
              #749644
              Nigel Graham 2
                @nigelgraham2
                I don’t know if a used kitchen-cleanser spray bottle would suffice. For querying compatibility WD-40 seems to be mostly white spirt with some light oil dissolved in it.
                #749672
                Bo’sun
                  @bosun58570
                  Done something similar to Bernard.  When used as a cutting fluid, it saves spraying (and wasting) WD40 where it’s not needed, and is of course is more accurate for say, putting in a drilled hole.
                  #749689
                    In my experience, the answer is ‘maybe’.    Some work well, others fail quickly, usually because the pump stops pumping!   Never dissected a failure to be sure but I guess it’s because the piston ring, valves or nozzle are made of a plastic that’s attacked by the liquid.
                    As we have no idea what spray bottles are made of and little knowledge of plastics and solvents, it’s hard to choose one!  However, the kitchen type are so cheap, it’s worth experimenting.  If one doesn’t work, throw it away and try another.
                    Garden sprayers are more likely to resist solvents other than water, but they are on the pricey side!   Twenty years ago I successfully prayed a spirit based wood-preservative out of a Hozelock 7l pump bottle, which still works.   Can’t guarantee that Hozelock’s current model will do the same;  the design or materials may have changed!
                    Clive Foster
                      @clivefoster55965
                      In my experience the official WD40 sprayers that come with one gallon / 5 litre bottles outlast the contents of the bottles.
                      I’m up to 4 now, one in the garage and one in the workshop with WD40 inside, one for diluted Rocol Ultracut synthetic coolant and one unused in stock for when one of the others goes down. I’m about halfway down my current 5 litre bottle so it will probably be best part of 2 years before another bottle and sprayer arrive.
                      #749731
                      Vic
                        @vic
                        You could try this with a used WD40 spray can?
                        https://youtu.be/doLPFPeJ6JE?si=YHVn7XI7FLiJnu-X
                        You can buy commercial ones but they are quite expensive.
                        #749742
                        Oldiron
                          @oldiron
                          Been using the same wd40 spray bottle that came free with 5ltr container for last 4 years or so with no problems. A mate uses a surface cleaner spray bottle and that seems to work ok.
                          #749755
                          Vic
                            @vic
                            What are folks using WD40 for in such large quantities? I have a can of the stuff but rarely use it, mostly for tapping aluminium. When that runs out I’ll likely mix up a white spirit/oil mixture.
                            I sprayed the table of my first milling machine many years ago to mistakenly stop rust in the winter. When I went out to the shed a few weeks later the table was covered in rust. Strangely other bare metal parts not sprayed with it were fine. You learn by your mistakes.
                            #749764
                            Nigel Graham 2
                              @nigelgraham2
                              The clue is in the name, “WD” – Water Dispersant.
                              Despite its own label claims its use as a lubricant is minimal (in fact it washes out existing lubricant), and the little anti-corrosion protection it gives is short-lived.
                              I suspect a lot of the “large quantities” is due simply to using sprays that cannot avoid wasting a lot of it per dose – most of it when the object is small!
                              It is often better to use a brush for treating small areas.
                              #749769
                              Bo’sun
                                @bosun58570
                                Agree with Graham.  That was the essence of my earlier post.  Unless of course we’re missing something?
                                #750138
                                David K
                                  @davidk77137
                                  Search hairdressing spray bottle on ebay , i bought a pack of 6 and they have been great.
                                  #750159
                                  Vic
                                    @vic
                                    When I worked as a mechanic we used to get through a fair bit of WD40, mostly on rusted nuts etc. The garage eventually started buying 20L drums of a generic product. It worked just as well but we didn’t like the plastic spray bottles as much as the WD40 spray cans.
                                    #750203
                                      Yes, something has been missed!   It’s that WD40 is a convenient multi-purpose liquid, handy for several different jobs.
                                      I first used it to dry out car ignition leads : a common problem in the good old days!  It’s also a good cleaner, dissolving grease, oil, tar and many glues.  Cleaning and drying both involve largish quantities, where a spray makes sense.
                                      The liquid is also a moderately effective penetrating oil and short-lived lubricant, plus it does a good job as a cutting fluid, especially Aluminium.  Much smaller quantities are needed, and spraying isn’t clever.
                                      Although WD40 is noticeably inferior to specialist products it does a reasonably good job on several workshop tasks and is unlikely to damage anything.   Same can’t be said of using specialist products for other than their intended purpose!    Spraying cutting fluid on a damp car engine is unlikely to help, and glue remover is a rotten penetrating oil!
                                      bernard towers
                                        @bernardtowers37738
                                        And using a spray bottle of WD40 on a lathe is asking for trouble as its oil removal capabilities soon show up with a lathe bed/crosslide etc with no sideway on it hence the use of a drip feed bottle.
                                        #750291
                                        Oldiron
                                          @oldiron
                                          Don’t know about anyone else but I always clean and re-oil my ways after every use. SO the wd40 I use on aluminium as a cutting lubricant is no trouble at all.
                                          #750531
                                          Phil Boyland
                                            @philboyland37326
                                            Hmm, interesting reading, I will get a new cheap sprayer and go from there then. Maybe I have just been unlucky with them.
                                            Cheers for the hints n tips
                                            #750540
                                            Vic
                                              @vic
                                              I’ve found empty supermarket spray bottles of various cleaning products to be far better than the empty ones they sell in Garden Centres, which seem to be designed to fail?! Sadly some don’t have screw tops so refilling is difficult.
                                              #750604
                                              Bo’sun
                                                @bosun58570
                                                “CIF” kitchen and bathroom spray bottles have screw tops to facilitate refiling with their concentrated refills.
                                                #750635
                                                Vic
                                                  @vic
                                                  Yes, I noticed some while ago a few bottles are designed to be refilled. I do seek out products that have screw tops just in case I need a sprayer. Most of them tend to be cheaper supermarket own brands.
                                                  #750637
                                                  Vic
                                                    @vic
                                                    Slight thread hijack. My “suds” spray bottle is getting low, are there any cheaper alternatives to proper soluble machine oil?
