Morning All,
I have a Boxford STS 10 -20 which is in generally good condition. However, if I put a dial indicator on the side of the spindle nose and push and pull the spindle at right angles to the spindle bore, I get plus/minus 0.0005 (13 microns) movement indicated.
I asked this on the Boxford user group and got a reply with +/- 'a couple of microns', which was more like I would expect.
I tried adjusting the bearing pre load in accordance with the manual, but this seemed to make no difference.
Is this play in the spindle normal. and has anyone had success in reducing this play?
many thanks,
