Speed Control or Countershaft for Flexispeed Lathe?
Home Forums Workshop Tools and Tooling Speed Control or Countershaft for Flexispeed Lathe?
Viewing 25 posts - 1 through 25 (of 41 total)
  • #176160
    James A
      @jamesalford67616
      The motor for my Flexispeed arrived yesterday and looks good. I now need to set it up on the machine and am not sure which would be better to use to reduce the speed: a PCW speed controller or a countershaft. The motor speed is 1,350 RPM.
      I seem to recall somewhere that using a countershaft is more effective at reducing chatter than a direct drive, but am not sure whether this is the case.
      I would appreciate ideas.
      Thank you.
      James.
      James A
        @jamesalford67616
        #176163
        Les Jones 1
          @lesjones1
          Hi James,
          First. What kind of motor is it ? Single phase / 3 phase induction motor. Series (Universal.) , shunt or permenant magnet ? I do not know what a PCW speed controller is. Do you mean a PWM (Pulse width modulator.) speed controller ? Even with a speed controller I think it is a good idea to have a few belt ratios to give you more torque at lower speeds. (Unless the lathe has backgear.)
          Les.
          #176164
          James A
            @jamesalford67616
            Les,
            Thank you.
            It is a single phase capacitor run motor (not sure about induction or other). I did mean PWM and the lathe has a back gear.
            James.
            #176166
              James,
              As I'm sure Les will be able to explain in detail … that type of motor does not lend itself to electronic speed control.
              I would definitely go for mechanical speed reduction … preferably using Poly-V pulleys and belts.
              [there have been several threads on the forum, discussing the merits of these]
              Les Jones 1
                @lesjones1
                Hi James,
                I agree with Michael's comments. A capacitor run motor is a form of induction motor.
                Les.
                #176206
                James A
                  @jamesalford67616
                  Thank you for the advice. I take it then that induction motors do not like speed controllers.
                  Is there any advantage in a countershaft other than offering more ratios than direct drive?
                  #176211
                  Les Jones 1
                    @lesjones1
                    Hi James,
                    Single phase induction motors would require a very complex design of speed controller. As well as a variable frequency supply (Which is quite easy to achieve.) they would need some way of providing a phase shift to the auxiliary winding. With a fixed frequency the capacitor does this but as the frequency is changed the value of capacitor would need to be changed. A 3 phase induction motor is relatively easy to change its speed by changing the frequency and amplitude of its power supply. This is why changing from a single phase motor to a 3 phase plus a VFD is so popular.
                    Les.
                    #176215
                    Roderick Jenkins
                      @roderickjenkins93242
                      The big advantage of the countershaft is that the full torque of the motor is always available throughout the speed range. There are some very sophisticated variable speed systems available for various other types of motors but, while they are very convenient, none of them provide the full torque (and therefore power) of the motor at the lower speeds.
                      Rod
                      #176232
                      Roderick Jenkins
                        What I should have said was that the stepped pulleys from the countershaft to the lathe spindle give you the speed variation. The motor to countershaft pulley ratio brings the countershaft speed down to a suitable value for the lathe whilst still retaining the full torque/power available from the motor. If you had a motor running at 500 rpm then you wouldn't need a countershaft.
                        Rod
                        #176264
                        James A
                          @jamesalford67616
                          Thank you for all of the replies. I'd best go and find some pulleys and make up a countershaft.
                          James.
                          #176281
                          WorkshopPete
                            @workshoppete
                            Hi All
                            Is 1350 RPM for an induction motor not odd should it be either 950 or 1675 rpm for 50 hz? ( see James first post).
                            Peter
                            #176283
                            Les Jones 1
                              @lesjones1
                              Hi Peter,
                              I don't know haw you have calculated the speed for a 50hZ 4 pole motor. Your value of 950 RPM is about right for a 6 pole motor. The synchronous speeds for 4 pole and 6 pole motors would be 1500 and 1000 RPM (50 x 60 = 3000 3000/2 = 1500, 3000/3 =1000) There always has to be some slip so current flows in the rotor bars so the actual speed is always a bit less than synchronous speed. I agree that 1350 rpm does seem a bit low (I would expect 1400 – 1450 rpm.)
                              Les.
                              #176284
                                For info.
                                On 10-Jan-2015, in his previous thread, James kindly posted the ebay link to the motor that he was buying.
                                Edit: [quoted]
                                Michael,
                                Here it is as an actual link.
                                James.
                                Edited By Michael Gilligan on 17/01/2015 08:52:47
                                #176293
                                James A
                                  @jamesalford67616
                                  Posted by Peter Newby on 17/01/2015 08:16:48:
                                  Hi All
                                  Peter
                                  I have just checked the motor and realsied that the correct listed speed is 1,370 RPM, not 1,350 as I originally stated. Sorry for any confusion.
                                  James.
                                  #176294
                                  Ian S C
                                    @iansc
                                    A motor that size would usually be a shaded pole type, and probably inefficient enough to run at 1350rpm. Two shaded pole motors that I have, including the one that drives my Super Adept lathe require a capacitor to run.
                                    Ian S C
                                    #176298
                                    Bob Brown 1
                                      @bobbrown1
                                      RDG do multi groove pulleys may be suitable
                                      Bob
                                      #176303
                                        James,
                                        You mentioned, on your other thread, that the lathe was a Flexispeed Meteor II
                                        If you haven't already done so; the lathes.co.uk page is a very good place to start.
                                        … and perhaps create an Album here, with some photos of yours for us to see.
                                        WorkshopPete
                                          @workshoppete
                                          Sorry Les
                                          Yes of course you are right Having worked on both sides of the pond I was getting 50hz and 60hz speeds mixed up but still 1370 seems very slow.
                                          Peter
                                          #176366
                                          oldvelo
                                            @oldvelo
                                            Hi James
                                            Can I add a little more info on "Chatter"
                                            "I seem to recall somewhere that using a counter shaft is more effective at reducing chatter than a direct drive, but am not sure whether this is the case"
                                            Here is a link to a query I posted on another forum why my lathe with a 180 volt DC motor with speed control ran so much smoother than the original AC motor. May be of interest to you and others following this thread.
                                            http://www.homemodelenginemachinist.com/showthread.php?t=17383
                                            Thanks to Ken for the full explanation of why this is so.
                                            Have you considered a DC drive and speed control. Personally I think they are Ideal for the home workshop machine tools.
                                            Eric
                                            #176410
                                            James A
                                              @jamesalford67616
                                              Thank you all for the extremely helpful and detailed replies.
                                              Bob: thank you for the link to RDG which I shall look at.
                                              Michael: thank you for the link to lathes.co.uk which, as you say,is very good and helped me to clarify the spindle thread. I can now keep a better eye out for any 1/2" BSF faceplates or chucks…………
                                              Eric: I shall read you link about chatter. I did consider DC rather than AC and pulleys, but the DC things that I found looked very expensive, unless I was looking at the wrong type of thing.
                                              I am happy to create an album on the lathe once I have cleared the garage enough to find my work bench again. I currently contains large amounts of my son's BMW E30 which he is rebuilding and a pile of kitchen bits from work in the house.
                                              James.
                                              #185598
                                              James A
                                                @jamesalford67616
                                                For a variety of reasons, mainly being busy rebuilding the kitchen and now the workshop, I have yet to set up this lathe. I have been looking for a set of suitable pulleys to make up a countershaft, but still like the idea of electronic control if affordable and practicable.
                                                I have seen these on E-bay and wonder whether anyone can suggest whether either would be suitable for a single phase, capacitor start AC motor of 120 watts?
                                                or
                                                Thank you.
                                                James.
                                                #185607
                                                Les Jones 1
                                                  @lesjones1
                                                  Hi James,
                                                  The simple aswer is no and no. Single phase induction motors are not suitable for speed control. I did see a design in the "Elektor" magazine once that claimed to work but I would not reccomend it. The solution is a 3 phase motor with a VFD or a permanent magnet or shunt DC motor with a suitable PWM speed controller or brushless DC motor with a suitable speed controller.
                                                  Les.
                                                  #185621
                                                  Ian S C
                                                    @iansc
                                                    When you make up a counter shaft, as well as the 3 pulleys to the lathe, it's worth while putting a 2 or 3 speed pulley from the motor to the counter shaft, that along with the back gear gives you 12 speeds, and if you work it right, your low speed could be 30 rpm or less, just don't go for excess speed at the top end. Use HSS tools, be prepared to run a bit slower, and the wee lathe will work to the maximum it can handle.
                                                    Ian S C
                                                    #185655
                                                    James A
                                                      @jamesalford67616
                                                      Thank you both for your replies.
                                                      Les: that is pretty much what I had expected, but it was worth checking, especially at the low price of the two controllers.
                                                      Ian: a good idea about the additional speeds. I shall see what I can find in the way of pulleys.
                                                      James.
