Southbend 13″ lathe.
Home Forums General Questions Southbend 13″ lathe.
  • #382208
    Bill York
      @billyork72513
      Good morning guys and dolls, I am refurbishing a Southbend 13" lathe and it needs complete replacement of the wicks and felts, can anyone steer me towards a supplier, I also need a parts/disassembly/reassembly manual if there is such a thing. Any info would be great and appreciated.
      Bill York
        @billyork72513
        #382215
        John Rudd
          @johnrudd16576
          #382216
          Bill York
            @billyork72513
            Brilliant, many thanks. Still need a UK supplier for the wick and felt.
            #382218
            Chris Evans 6
              @chrisevans6
              I had a Southbend "Heavy Ten" of 1942 vintage for 45 years. Eventually parted with it for a bigger lathe.
              Boxford lathes are a copy of the Southbend so maybe a look at their spares supply may yield what you need ?
              #382221
              Bill York
                @billyork72513
                Posted by Chris Evans 6 on 25/11/2018 11:04:13:
                This one is a 1938 supplied to the Ministery of supplies for the war effort and was on a Royal Navy ship for many years before ending up in a goverment test station. I have included some pics if you want to check my albums.
                #382230
                Pete Rimmer
                  @peterimmer30576
                  Steve Wells' website is pretty much the go-to repository for South Bend info and literature.
                  http://www.wswells.com/
                  How much of a refurbishment are you doing? I'm currently renovating a Heavy 10. Bed and saddle re-ground, all the other ways re-scraped. Full strip and rebuild of the rest of the mechanicals and of course re-painted all over.
                  Edited By Pete Rimmer on 25/11/2018 11:55:06
                  #382234
                  ega
                    @ega
                    Posted by Bill York on 25/11/2018 10:59:30:
                    If you are cutting your own felts, I can supply the material (thick ex-papermaking felt).
                    Edited By ega on 25/11/2018 12:01:42
                    #382245
                    Bill York
                      @billyork72513
                      Posted by Pete Rimmer on 25/11/2018 11:51:35:
                      Ground up strip and rebuild, repair as and when needed, no regains or scrape, new paint and I will be keeping it and selling my other lathe which is more suited to a model maker which I an not.
                      #382246
                      Bill York
                        @billyork72513
                        Posted by ega on 25/11/2018 12:01:20:
                        That would be great, how much
                        #382247
                        Bill York
                          @billyork72513
                          #382249
                          Bill York
                            @billyork72513
                            #382266
                            ega
                              @ega
                              Posted by Bill York on 25/11/2018 12:34:05:
                              Just PM me your address and say what size you want and I'll post – no charge, but consider "paying forward".
                              #382323
                              Brian Wood
                                @brianwood45127
                                Bill,
                                I wonder if the Myford S7 front spindle bearing oiling wick is the right diameter for your wicks? From memory they are about 1/4 inch in diameter
                                #382324
                                Pete Rimmer
                                  @peterimmer30576
                                  South Bend wicks are much larger than 1/4" Either 7/16" or 1/2" I didn't measure mine but they are quite fat with a spring around them.
                                  #382325
                                  Pete Rimmer
                                    @peterimmer30576
                                    Posted by Bill York on 25/11/2018 12:32:31:
                                    I don't blame you for not wanting to grind the bed, it's quite expensive and now that Brian's retired I don't know who else I'd take it to. For sure though I would give serious consideration to working over the cross slide and compound ways. I don;t think I've ever seen a used lathe more than a few years old that didn't need some kind of attention to the minor ways.
                                    #382328
                                    Bill York
                                      @billyork72513
                                      Posted by Pete Rimmer on 25/11/2018 19:30:29:
                                      Yes the SB spindle oiler is about 1/2" x 4" and as you say have a spring action that keeps the hard felt tip in contact with the spindle.
                                      #382330
                                      Bill York
                                        @billyork72513
                                        Posted by Pete Rimmer on 25/11/2018 19:34:04:
                                        I will have to do some work as you say on the minor ways but the lathe will not be needed to work to 2/10ths
                                        #382356
                                        Robbo
                                          @robbo
                                          You might also like to look at the ebay store (for South Bend) at **LINK**
                                          Bit eye-watering though crying
                                          #382361
                                          thaiguzzi
                                            @thaiguzzi
                                            +1.
                                            I'd use this guy. Very helpful, has all the common consumables, parts lists, and his own very good rebuild manuals.
                                            The go-to-guy on 9-14" Southbends.
