Sourcing HSS Slot drills,end mills, T-slot etc etc
Home Forums Beginners questions Sourcing HSS Slot drills,end mills, T-slot etc etc
  • #130855
    SteveI
      @stevei
      Hi,
      With reference to the never ending debate about quality and country of origin I am looking for some advice regarding sourcing HSS slot drills and end mills.
      I have a few threaded shank new old stock clarkson, dormer etc all uk made and a small and medium R8 Clarkson auto lock chuck. What I have today is very limited and a mixture of metric and imperial. I am looking to invest in what I need to work my way from raw novice to beginner and onwards. I am following MEW back issue articles such as those by Harold Hall and mostly attempting to make myself small items of tooling.
      I'd like to invest in good quality cutting tools, and plan in the longer term on learning to re-sharpen them. I don't have access to anything close to affordable next day delivery from any suppliers so the idea of buying tools I can resharpen appeals to me. I have access to T&C grinder. Note that I have some indexable tip end mills to provide the time buffer whilst I learn the resharpening and to be used on hard skinned castings etc,
      What do people recommend, source more new old stock? If so what brands? Or buy brand new from certain brands/suppliers? I have found that when looking at new old stock some offers are not as sharp as others… Should I target throw away cutters and ditch resharpening?
      I appreciate that is a lot of questions and perhaps I am most interested in peoples opinion of good quality slot drills and end mills. I don't anticipate much more than ~25mm / 1" diamters will be needed.
      Thanks,
      Steve
      #6888
      SteveI
        @stevei
        #130870
          For most things below 10mm-3/8" I use the three flute disposables, usually Hertel when J&L have them on special which is most of the time. The sales flyer can be viewed on their site as can their main catalogue but its worth getting one sent to you.
          Above that then either Hertel or Dormer also from J&L for best.
          I also use cheap cutters from Richon in Hong Kong which can be regarded as disposable and you don't mind taking the edge off them if you hit a hard spot in a casting
          Cutwell are also worth looking at.
          J
          #130878
          Douglas Johnston
            @douglasjohnston98463
            Private sellers on ebay can be a good source of milling cutters (the commercial "buy it now" listings rarely give a quality bargain) and I have had quite a few good quality buys this way. You have to be selective however, since there is plenty of rubbish out there. Tipped cutters have there uses, but are no good for a lot of work, so it is not possible to rely on them for most work.
            Doug
            #130879
            Phil P
              @philp
              I use Kirgeng M.E. Services for most of my small cutting tools. His stock is all good quality mostly British made like Dormer, Presto, Clarkson etc. Often you can choose between new or good second hand items. His postage rates are not a rip off either.
              Give him a ring on 01509 672025, and ask him to post you a catalogue.
              He normally has a stand at Harrogate and Midlands exhibitions as well.
              Phil
              Edited By Phil P on 28/09/2013 09:21:53
              #130882
                I don't think Dormer have been British MADE for some time, looking at mine
                Drills – Brazil
                Milling cutters – Italy
                Taps – Sweeden
                Likely to be the same case with teh other brands.
                #130885
                mgnbuk
                  @mgnbuk
                  We use mainly coated 3 flute long series HSS cutters from Cutwel at work. I believe that these are South Korean in origin. We don't have cutters under 25mm reground, as the regrind cost is more than new cutters (don't have regrinding facilities "in house" ).. On occasions we have used their solid carbide cutters & generally use their inserts. J&L have tried to tempt me to use them, but they have been unable to supply anything like the Cutwel tools we use & their prices for lower spec. offerings is always more than Cutwel.
                  Cutwel's service is excellent, most items are ex-stock & are shipped the same day as ordered. Delivery is RM for small items, next day courier for bigger orders. It is worth getting on the e-mail list, as they regularly have "Buy two get one free" limited period offers.
                  Edited By JasonB on 28/09/2013 12:40:32
                  #130888
                  Phil P
                    @philp
                    Posted by JasonB on 28/09/2013 10:08:46:
                    Drills – Brazil
                    Taps – Sweeden
                    Jason
                    I think most of Kirjeng's stuff is "old stock" from stores clearance sales etc. So more likely to be decent quality.
                    I have never had a problem with anything bought from them.
                    Phil
                    #130897
                      The new stuff is still quality just made to a good spec not a budget price.
                      J
                      #130914
                      SteveI
                        @stevei
                        All,
                        Many thanks for the replies. You have educated me about a few new suppliers. One last question if I may, when reading old articles from MEW "throw away" cutters are often mentioned and seldom in a complimentary way. Are they much better now?
                        Thanks,
                        Steve
                        #130915
                          Yes provide you don't buy really cheap un-named ones.
                          There is also nothing to stop you resharpening them its just that in commercial use its not cost effective to do so.
                          Edited By JasonB on 28/09/2013 16:14:12
                          #130918
                          Rik Shaw
                            @rikshaw
                            We have just sold our static caravan in Weymouth and therefore will not be regulars there in the future. So if you come from that neck of the woods I don't mind revealing my secret supplier.
                            Dave the tool bloke at the Wednesday market in Dorchester sells a lot of second hand tools and some new as well. I have stocked up my workshop over the years buying stuff from him – and blokes like him.
                            If you pay him a visit give him my regards and tell him the tall bloke with a grey beard sent you.
                            Rik
                            #130924
                            Sub Mandrel
                              @submandrel
                              With very small FC3 /throwaway cutters you could break a lot regardless of quality – I just did a count up: 11 intact ones, 8 broken ones, the latter all <1/8" or 3mm
