Source of neat cutting oil
Home Forums Hints And Tips for model engineers Source of neat cutting oil
  • #286829
    Nigel Toll
      @nigeltoll39934
      Hello All,
      I've been using EP90 gear oil as a cutting oil. It seems to work well, if a bit smelly. As an old Land-Rover owner I change the gear and axle oils every year which gives me a supply of about 2 gallons.
      Nigel Toll
      Nigel Toll
        @nigeltoll39934
        Cutting oil
        #286846
        Jon Gibbs
          @jongibbs59756
          Hi Nigel,
          I bought 5L of neat Supercut cutting oil from ebay seller lubetechoil for £20 delivered.
          This link might work… **LINK**
          No afiliation but at that price for a lifetime's supply it seems hard to beat.
          HTH
          Jon
          #286887
          Stuart Bridger
            @stuartbridger82290
            I have always used NC-110 from Hallett Oils. Had good service from them in the past, however they now seem to have dropped their ME section from their website. May be worth a call though ?
            Richard Marks
              @richardmarks80868
              #286894
              Chris Evans 6
                @chrisevans6
                Having run series Land Rover's for over 35 years EP90 runs through my veins. I will give it a try as cutting oil but think the cat pee smell will put me off.
                #286898
                Howard Lewis
                  @howardlewis46836
                  I don't think that Warco will supply by post/carrier, except with a machine. You can buy / collect from their stand at shows.
                  Would not have thought that EP90 would be a suitable cutting fluid. The Extreme Pressure feature could well prevent the tool forcing its way through the oil film.
                  Even neat cutting oil will show this at times with a very fine feeds. The tool advances , barely cutting, and then the swarf comes flying of for a short time, before the process repeats itself.
