To put you out of your misery, this is what it says on the side of the crate.
It would seem that ARC Eurotrade are doing their bit for the enviroment and not using polystyrene packaging which just goes to landfill, instead they have taken to packing around the machines with bits of tooling, etc.
Looks a bit like someone did a supermarket sweep of the ARC warehouse and as you can see there is a 150mm rule in there so one right answer.
Just need to work out what all these bits do and how to use them
J
