Hi Bill,
you can also get different melting point soft solders apart from the silver solders that Jason mentions. From my model locomotive work in 00 gauge building brass kits I have a number of solders covering a temperature range from 44 degrees C up to around 230/240 degrees C with several in between. I would solder the larger items with the high temp solder then work down to the very small parts using the lower temperature solders as much less heat (different to, but linked to lower temperature) is required.
Also it is not a case of one gas torch fits all sizes. I have and use several, including a large Sievert propane (with several nozzles), a normal size butane torch, a small type of butane similar to the ones sold for kitchen use and a pencil torch as well as a range of soldering irons. it also depends on timing and practice. Don’t give up just keep trying.
You can also use ‘bands’ of black, soft iron wire to strap parts together while soldering (both soft and silver). I use the stuff that florists sell on reels. When using this, make a small loop in the middle of the wire (twist once or twice) then wrap the parts, twisting the ends of the wire (very malleable – use fingers only) the loops made first can then be twisted to tension the wire around the parts after wrapping. Several wires can be used around different parts. Be creative when planning your soldering.
Best regards
Terry
Edited By Terryd on 23/01/2011 21:45:28
