Soldering Aluminium
Soldering Aluminium
Home › Forums › General Questions › Soldering Aluminium
  • #743498
    John MC
      @johnmc39344
      I am fitting a bush in to an aluminium casting, the bush will have an external thread in to the casting for mechanical security.
      I thought it would be nice to run a bead of solder around the bush, mainly for appearance and back up oil tightness.
      My usual go to for this would be something like Lumiweld or similar.  Problem is the heat needed.  There are components fitted near the bush that I do not want to disturb or get too hot, certainly not to Lumiweld temperatures.
      My question is, is there such a thing as low temperature solder for aluminium.   Something that can be used with a soldering iron?  Mechanical strength is unimportant.
      Any other ideas.  I have tried things like “liquid metal” in the past.  Did the job but not the same colour as the parent metal.
      I’m open to suggestions, any ideas?
      #743500
        Andrew Tinsley
          @andrewtinsley63637
          Jason has the correct answer! From memory you need about 200 degrees C to solder with Alusol. Last time I looked the stuff was an eyewatering £6 a metre from CUP or a few hundred gram reel from Farnell at £40 per reel. After paying through the nose to CUP, I purchased a reel from Farnell.
          #743546
          noel shelley
            @noelshelley55608
            You will need the right flux I suspect ? Or is it cored ? Noel.
            #743549
              Cored, saves the excessive postage on the separate flux.
              I’m sure if anyone asked CuP they would do a good price for a reel ot large quantity as the other solders they list full reels of are a better buy than short bits plus you get all the advice from them included.
              #743553
              Trevor Drabble 1
                @trevordrabble1
                The Solders and Flux company also sell Alusol. No connection with them other than as a satisfied customer.
                #743593
                John MC
                  @johnmc39344
                  Thanks for the replies.    I’ll give cored Alusol a try.    This still needs a some preheating of the work piece of the work before soldering, hopefully not too much.  I’m hoping my large soldering iron will bring the heat up locally to do the job.
                  Also, I’ve noticed that these types of solder prefer pure aluminium, silicon is the enemy and it will not solder.  One component is cast, the other wrought so there will be, likely, be some silicon present.
                  I’ve got two chances, I’ll give it a go and report back.
                  If it doesn’t work then plan B will be an epoxy type filler.
                  #743607
                  bernard towers
                    @bernardtowers37738
                    If the bits are large you could preheat with a hotter gun/hairdryer, it shoul d be a help.
                    #743621
                    Hopper
                      @hopper
                      On John MC Said:
                      ..  I have tried things like “liquid metal” in the past.  Did the job but not the same colour as the parent metal.
                      Can you make the theaded bushing a top-hat shape so the top-hat flange on the end obscures the threaded joint and any adhesive in it? You could even radius the outer edge of the flange and bead blast it so it looked like a casting.
                      #743643
                      John MC
                        @johnmc39344
                        The problem is that the bush passes through a casting that curves in all directions.   If it was flat then it would be so much easier!
