Softening epoxy
Softening epoxy
Home Forums General Questions Softening epoxy
Viewing 13 posts - 26 through 38 (of 38 total)
  • #813731
    old mart
      @oldmart
      Acetone does attack epoxy to some extent, we had tanks of acetone to rinse off Skydrol hydraulic fluid used in civil airliners because it is non flammable. The rinsing had to be fast as the eoxy paint finishes would suffer if exposed to the acetone for more than a few seconds. We had to test various hydraulic sub assemblies including shimmy dampers and they were always contaminated externally with the Skydrol (phosphate ester) which would not be safe to handle without being rinsed off before final inspection and packaging. You wouldn’t want to get any in your eyes, it hurts.
      michael howarth 1
        @michaelhowarth1
        I had a tube of epoxy that went hard, took it back to the shop, he exchanged it quite happily but told me to microwave the dodgy tube – it worked a treat.
        Mick
        #813791
        John Haine
          @johnhaine32865
          Hmm – in my case the tubes are metal so microwave wouldn’t work!  Anyway this is a brass block with epoxy (Araldite?) that has cured over 30+ years.
          It has sat in a jam-jar of acetone since last Wednesday with no sign of softening, so I think I will be making a new block.  I have a brass bar end which has one hiding inside…
          #813834
          old mart
            @oldmart
            Bad luck with the acetone, MEK is hard to get now as it is harmful to the ozone layer. It’s amazing what lurks inside a block of metal when you have the machinery dig it out. What about simply running a milling cutter straight through the leds and glue to remove them?
            #813861
            KEITH BEAUMONT
              @keithbeaumont45476
              O;d Mart,
              Your saying you had tanks of acetone,as a rinse,”because it is non flammable” does not sound right to me,  Acetone is very flammable.
              Keith.
              #813895
              John Haine
                @johnhaine32865
                <p style=”text-align: left;”>OM, as this is a sort of conservation job I want to preserve the original block, given it’s shape I wouldn’t want to risk drilling or milling out the components.</p>
                #813907
                  This one-pager comes from a respected source, John … but it doesn’t get you much further:
                  https://www.tedpella.com/technote_html/Reworking_Cured_Epoxy.pdf
                  Dave Halford
                    @davehalford22513
                    Epoxy gives up when exposed to soldering iron temperatures.
                    #813914
                    John Haine
                      @johnhaine32865
                      Not this stuff!
                      #813938
                      old mart
                        @oldmart
                        On KEITH BEAUMONT Said:
                        O;d Mart,
                        Keith.
                        Read my post again, Keith.
                        #814042
                        KEITH BEAUMONT
                          @keithbeaumont45476
                          Read again and again and it still sounds as though you are saying Acetone is non flammable. Where am I going wrong?
                          Keith.
                          #814069
                          duncan webster 1
                            @duncanwebster1
                            He’s saying the hydraulic oil is non inflammable, but it’s ambiguous. The oil is based on poly phosphate ester, which is quite good at removing skin. We wouldn’t have anything to with it. Another non flammable oil is water glycol mix, but you have  to work at lower pressure, heavier cylinders and pumps. If yoh want thd best of both worlds then use Fomblin, but it’s expensive. Per fluoro poly ether if I remember correctly
                            #814117
                            Robert Atkinson 2
                              @robertatkinson2
                              If you think Skydrol doesn’t burn read this (or look at the pictures)
                              https://asn.flightsafety.org/reports/2012/20120221_C130_130342.pdf
                              If it hadn’t been on take off with a prompt decision to abort they would have crashed. I’ve seen the aircraft in person and the images don’t do justice to the level of damage.
                              Robert.
