Softening epoxy
Softening epoxy
Home Forums General Questions Softening epoxy
Viewing 25 posts - 1 through 25 (of 38 total)
  • #813131
    John Haine
      @johnhaine32865
      I have a small brass block with holes into which some LEDs are fixed using epoxy.  The LEDs are 30 odd years old and have been running continuously so their light output is poor, so they need replacing. The glue is probably Araldite judging by its colour. I’m going to try putting the item in a jar of acetone and leaving it for a few days as I have seen this recommended. Other ideas welcome!
        The encapsulation material of the LEDs will probably dissolve before the Araldite … but I guess that’s not important.
          As an alternative, I would suggest thermal shock
          i.e.  embrittlement rather than softening.
          Liquid Nitrogen ?
          Andrew Tinsley
            @andrewtinsley63637
            Yes the liquid nitrogen trick works. But don’t have access now I am retired.
            Andrew.
            #813154
            Roderick Jenkins
              @roderickjenkins93242
              Half a century ago I removed stainless steel mesh epoxied to aluminium screen printing frames using a proprietary liquid that smelled strongly of oil of wintergreen, which I believe is mostly  methyl salicylate.  I wouldn’t be suprised if it also included methylene chloride which is generally banned for domestic use. So, that’s not much help.  There do appear to be plenty of proprietary solutions available though.
              Rod
              #813155
              Macolm
                @macolm
                There are chemical “solvents” that disintegrate most epoxies. One brand I remember is Ardrox which seems to be still available. The product we used had a quantity of oil that floating on top; you shook the can and poured out what you needed, then lowered the item through the oil to hang in the noxious brew. It was quite slow acting, but did not attack metals and most plastics.
                #813158
                John Haine
                  @johnhaine32865
                  I guess the best thermal shock I can do is freezer to boiling water, or maybe hot cooking oil to ice bath.  The electronic components need replacing anyway so it doesn’t matter if they get destroyed in the process.  Rod you mentioned “proprietary solutions”, please could you point me to one?  Also not obvious what Ardrox product to use, they have a wide range and their website doesn’t mention “epoxy”.
                  #813180
                    At that vintage, there’s a good chance that the Araldite was ‘2002’ or something similar … so you might find this of relevance:
                    http://silverbiplanes.com/SPECIFICATION_PDFS/British_DTD/DTD_900A_1988.pdf
                    Sorry, don’t have time to dig any deeper today.
                    Kiwi Bloke
                      @kiwibloke62605
                      Alternative ‘thermal shock’ – heat! Either the epoxy or the LED encapsulant will give up at domestic oven temps…
                      #813182
                      Dick H
                        @dickh
                        Google “epoxy” and “pineapple juice”.
                        #813187
                        Robert Atkinson 2
                          @robertatkinson2
                          Methylene chloride is a good choice but as noted is now generally banned particuarly as paint stripper. However you can buy small quantities as solvent for welding plastics. I use EMA Plastic Weld.
                          As the LEDs are not being re-used you could also use mechanical methods.
                          Robert.
                          #813200
                          Roderick Jenkins
                            John,
                            I did a quick web search to see if I could find something that would help me recall the name of the product that I used to use.  There were plenty of options but none that triggered my memory. I’m afraid I don’t have any experience of the modern preparations.
                            Rod
                            #813206
                            andy198712
                              @andy198712
                              Ardrox 204 I think it is. Is yellow and thick, it’s DCM paint stripper and melts away a lot of stuff not just paint, at work we use it to melt structural adhesive. Worth a google but to be honest the easiest method I would think to try first is heat.
                              what’s the rest of the part like? Can you apply much heat?
                              #813208
                              martin haysom
                                @martinhaysom48469
                                heat , use a hot air gun as it can be a bit stinky
                                #813217
                                Russell Eberhardt
                                  @russelleberhardt48058
                                  #813218
                                  John Haine
                                    @johnhaine32865
                                    Thanks for all the suggestions.  I’ve now immersed the item in a jar of acetone and will leave it for a few days to see what happens.  Failing that I’ll pop it in the oven…
                                    #813223
                                    Speedy Builder5
                                      @speedybuilder5
                                      Drill them out ?
                                      #813224
                                      John Haine
                                        @johnhaine32865
                                        I can risk damage to the block so drilling a last resort.  The Ardrox stuff is available in 25 litre quantity so expensive if it didn’t work!
                                        Thanks for that link Russell.  A bit ambiguous, but they mention acetone so let’s see how that gets on.
                                        I’ll report back when I have more information!
                                        #813241
                                        Georgineer
                                          @georgineer
                                          On John Haine Said:
                                          … maybe hot cooking oil to ice bath.  …
                                          A freezing mixture of ice and salt would get the temperature a lot lower, if the presence of salt wouldn’t be a problem (maybe cling wrap?).  Or there are the freezer sprays you can buy.
                                          George
                                          #813252
                                          Vic
                                            @vic
                                            I’ve used this method several times, it works well.
                                            #813312
                                            vintagengineer
                                              @vintagengineer
                                              MEK destroys most things.
                                              #813319
                                              John Haine
                                                @johnhaine32865
                                                Thanks – any idea where MEK can be bought?
                                                #813320
                                                Robert Atkinson 2
                                                  @robertatkinson2
                                                  The Ardrox 204 is mainly methylene chloride so may as well use the plastic weld. If you can seal it in a metal or glass container to limit evaporation when soaking. Additionally they should not supply Ardrox 204 to private users. MEK does not effect epoxy much in my experience.
                                                  Robert.
                                                  #813329
                                                  duncan webster 1
                                                    @duncanwebster1
                                                    The stuff used to glue plasticard, mek-pac, is still available. No idea whether it affects araldite
                                                    #813374
                                                    Martin Dilly 2
                                                      @martindilly2
