A DVD disc is digital, but the player the OP shows has separate analogue video and audio outputs, (yellow, red and black). So your DVD machine has a digital to analogue convertor which feeds these connectors.
Your television also has analogue video and audio connectors, (yellow, red and black), and most probably they are inputs.
So, as some have said; if you connect the yellow to yellow, red to red. and black to black with phono to phono leads between your DVD player and your television, and select the analogue input on your television source menu, (might be called 'ext' for external), you should be able to view and hear your DVD player. No need to buy an analogue to HDMI convertor, because your television has this built in.
Of course, you won't see or hear digital quality, because the signal will go from digital to analogue and back to digital again, which in consumer level equipment, will introduce signal degradation.
Something called component video, (Y, Pr, Pb), might be available from the SCART connector and if so, a component to HDMI convertor will give you better quality than going via the composite PAL signal that is present on the discrete analogue connectors. But component is still analogue, and rather than spend money on this, a brand new DVD player with HDMI output would be the most sensible option, avoiding any analogue step.
Edited By John Doe 2 on 07/02/2022 13:11:12
