Small thin hand files
Home Forums Workshop Tools and Tooling Small thin hand files
  • #361239
    Ron Laden
      @ronladen17547
      I did have a couple of small thin files (not needle files), one medium and one fine. They were approx 150mm long x 15mm wide x 2mm thick but I have lost them both, cant find them anywhere.
      I have searched on line but cant find anything similar unless I have missed them, any ideas on where I could get the same or similar. Ideally no more than 2mm thick but could just get away with 2.5mm max.
      Thanks
      Ron
      Ron Laden
        @ronladen17547
        #361242
        Anonymous
          Try searching for warding files?
          #361248
          Mike Poole
            @mikepoole82104
            They are sure to turn up as soon as the new ones arrive.
            #361250
            ronan walsh
              @ronanwalsh98054
              Aren't they called magneto files ? May help in your search.
              #361261
              Brian Wood
                @brianwood45127
                Posted by ronan walsh on 08/07/2018 18:11:50:
                +1 for Magneto files Brian
                #361266
                Bob Stevenson
                  @bobstevenson13909
                  https://www.hswalsh.com/search-products?search_api_views_fulltext=files
                  ….just for info; 'magneto' files are double sided, have none cutting edges and are smaller with toothed area about 55mm long and are good for confined areas difficult to reach with other files…..
                  "Warding files" are for cutting the wards of a lock or key,….have both edges toothed, are tapered,…come in several sizes smallest having toothed area about 70mm long.
                  #361268
                    Vallorbe do a 17mm x 2mm flat @150 long in a couple of different cuts
                    Vallorbe catalogue section
                    Edited By JasonB on 08/07/2018 20:54:41
                    #361270
                    Chris Evans 6
                      @chrisevans6
                      Do a search for narrow pillar file.
                      #361272
                      Mike E.
                        @mikee-85511
                        Search for Jeweler's files.
                        #361325
                        Ron Laden
                          @ronladen17547
                          Thanks guys for the info.
                          Jason, those Vallorbe files seem to be very close to the ones I had, thanks for that.
                          Ron
                          #361331
                          clogs
                            @clogs
                            have a look at Bahco, Swedish…….
                            the files of similar size are used for sharpening HSS chainsaw cutting chains…..
                            always on offer, just bought a few of diff shapes for €2 each last week, actually, they wanted more for the new file handle that were "also on offer"……..
                            I use mine a lot especially the small flat, deburring on the larthe and mill……my first 1 must be 10 years old and still sharp………they are quite fine tho……
                            remember if they don't get blunt on the chains, they'll do us a treat in the shed…..
                            just sayin………
                            #361351
                            Perko7
                              @perko7
                              My dad used to call them 'points files' for filing the contact breaker points in the car ignition distributor.
                              #361353
                              Ron Laden
                                @ronladen17547
                                Thanks clogs, I will have a look at those.
                                Ron
                                #361397
                                Jon
                                  @jon
                                  Also pillar files.
                                  All files went down the pan by 2003 same with hacksaw blades.
                                  Buy once buy the best Vallorbe however much it may hurt.
                                  Bahco are made in Portugal for many years avoid the integral plastic handled ones they will be worn in half a morning.
                                  #361413
                                  ronan walsh
                                    @ronanwalsh98054
                                    Posted by Jon on 09/07/2018 20:34:42:
                                    Also pillar files.
                                    Well filing went out of use really in the engineering, anywhere i worked anyway. No one was going to pay you to stand at a bench and file metal components. You either milled it, ground it, or chucked it away and got something that fit better in the first place.
                                    A real pity, i was taught to fit using files, and enjoyed it. If its good enough for Holland and Holland, Purdeys etc, i will persevere with it.
                                    #361415
                                    Mark Rand
                                      @markrand96270
                                      Those dimensions fit Oregon single cut, flat, chainsaw files very well (made by Vallorbe). Some of the best tools I own…
