Yes, it was the original mini I meant – and the clutch with its belleville washer was designed by Automotive Products (ie Borg & Beck).
A simple way to proceed is to find a washer of the diameters you can manage, and quite a bit more than the max load you need. Then use as many as it takes to give the max travel you need, alternately up and down.
Example: Lee 138-015-281, od = 7.14mm, free height = 0.58mm, load fully compressed = 271N, thickness = 0.38mm.
A stack of 40 of these has a free height of 23.2mm, compresses down to 15.2mm, and gives a load from 0 to 271N as you go through that distance*. More than adequate (but possibly too expensive?).
*NB it is not accurate to think of the 'rate' of a belleville washer, as they do not obey Hooke's Law (which is why they are brilliant for vehicle clutches).
The hysteresis (self damping) of rubber is much greater, especially with some synthetics – but this might be an advantage. But it is not so resistant to the effects of high temperature. Ditto Polyurethane but more so.
And Stainless is completely sun- and weatherproof, and can be polished, of course …
Cheers – Tim
Edited By Tim Stevens on 21/05/2014 09:15:53
