Hi Mark
Is this the belt type on your machine "Gates 5M710. PolyFlex® 8902-0710 V–Belt – 5M Section, 3/16 in Top Width, 27.95 in Outside Length, Polyurethane Material "
What is the motor power on your lathe as this size seems to be big enough for nothing bigger than around 1/8 hp. unless on very large diameter pulleys with very high peripheral speeds are used.
Polyurethane belts do not perform very well when excess slippage occurs when used as a clutch.
Being a convert to "Poly Vee Multi Rib Belts I ditched Vee Belts on my machines where ever possible and have run them trouble free for several years now.
Broken belt suggests that it is being used to attempt to transmit a high torque loading on a very small belt cross section.
This MAY help better prices LINK and in my VERY biased opinion a good deal
Eric
Edited By oldvelo on 10/09/2017 05:40:40
