Hi Stuart,
I presume you have done the appropriate checks on bearings/bushes/fuzz and gunge clogging the pump impeller and that the motor shaft turns freely? In which case:
I have a similar pump both in my Solar heated water system and in my solar heated under-floor heating system in my house – both pumps ( they are 2 speed as well) developed running/stall problems late in the 10 years of operation – both problems were due to the motor capacitors – they looked fine, but when measured with a capacitance meter, they had reduced from what should have been around 5uF, the one down to 3uF, the other to a shade below 2uF – replaced both and all is fine again…maybe the electrolyte dried out internally, and they dropped in value as a result
Swap them with new and I am sure they will work fine again.
Happy New Year!
Joe
