hi david,
it is because we have a decent test and inspection regime in UK clubs that on the whole problems are avoided.
in Australia they have a far stricter regime and a far more comprehensive set of regulations/boiler code.
i am here dealing with silver soldered copper boilers.
however i can assure you that miniature loco boilers do fail tests. there is a well known problem with the silversoldering of the Winson's/Modelworks 5"g Black 5 commercial boiler on the foundation ring joints.
i myself have cut up 2 boilers that failed tests and inspection.
i have personally come across 5 instances of the inner firebox crown collapsing, 1 case of a barrel longitudinal joint failing, and 1 outer wrapper to backhead seam leaking. i have forgotten the number of times ive seen a boiler fail with a leaking foundation ring or firebox hole ring to backhead leak.
ive seen people fit plain stays caulked with comsol instead of being threaded and nutted, or if plain, not silversoldered. ive seen inferior grade copper laminate. frequently extra stays have had to be specified and added.
ive seen faulty silversoldering due to inadequate heat, wrong flux, wrong grade silver solder, wrong gap size.
there are one or two notable examples of a UK miniature loco boiler 'exploding' in steam some years ago. there was a notable example with a 5"g B1 where the barrel joint failed.
i also recall one boiler (5"g Ajax) which had passed its tests but when on the track the driver left the blowdown partly open and went to get a cup of tea and the water level quickly got too low. the boiler had to scrapped due to irrepairable damage to the firebox.
do not expect some well known designers to have correctly described boiler construction in ME. thankfully all some years ago but Keith Wilson used to specify the wrong type of cheaper silver solder that is brittle, and Martin Evans used to describe how tubes should be a push fit in the plates! LBSC frequently specified sifbronze welding for the throatplate to barrel joint – which on certain designs if silver soldered causes cracking in later stages especially if silver soldered with oxy-acetylene.
cheers,
julian
Edited By julian atkins on 22/02/2016 12:37:34
