Simat 101 or Flexispeed lathe….I have to choose
Home Forums Workshop Tools and Tooling Simat 101 or Flexispeed lathe….I have to choose
  • #612333
    Julian Tolley
      @juliantolley83108
      I've had a Flexispeed large for years but recently a Simat 101 lathe cane available near me. I thought I would be able to mix and match but find the spindle is different (well the nose thread). So I now have to choose which one to get rid of. The Flexispeed uses oil for the main bearings while the Simat has grease filled fittings…not sure if they were a later feature or a modification. Anyone out there with experience of both…..and offer advice.
      #20782
      Julian Tolley
        @juliantolley83108
        #612362
        peak4
          @peak4
          My Simat is oil fed, rather than grease.
          Are you sure someone hasn't just drilled out the holes and added oil nipple like on a Myford.
          How about making a nose adaptor for one lathe or the other, or if you have access to a larger lathe, maybe make a new spindle for one of them to match the other.
          Bill
          #612378
          not done it yet
            @notdoneityet
            Plain bearings generally need oil lube whereas rolling bearings (ball, taper roller or needle) can use either.
            Compare wheel bearings on vehicles – they can go for 100,000 miles without trouble..
            #612687
            Geoff Mathews
              @geoffmathews47505
              Some Flexispeed lathes – but not all – were serial numbered and had a hand finished bed – if your Flexispeed is one of these it might be worth keeping.
              #612714
                The one that's in best condition! On paper the Simat looks like a refined Flexispeed, which is good, but not if the Simat's bearings have been damaged by being worked on grease. Buying second-hand we always risk being punished for the sins of previous owners!
