silver soldering bronze
Home › Forums › Beginners questions › silver soldering bronze
  • #6879
    michael burton 1
      @michaelburton1
      #130191
      michael burton 1
        @michaelburton1
        hi is it possible to silver solder oil filed bronze or would it completly ruin it? if there is without trouble is it just the normal proces i need to make 2 bushes up with a 20mm bore and would like to order the bushes in ready made,
        atb mike
        #130194
        JohnF
          @johnf59703
          Michael, Answer is no you cannot solder this material [presume you mean Oilite or similar?] and yes it would rui the material.
          Don't really understand your question though when you say you want to make up 2 bushes and/or order in ready made — why would you want to solder them?
          michael burton 1
            @michaelburton1
            hi ok just as i thort…… the reason for soldering was they needed to be mounted in 1/8'' plate and i was gunna buy the bushes ready made for ease guess il have to buy sum normal material now and make them myself
            #130225
              Posted by michael burton 1 on 19/09/2013 22:47:54:
              As John said; Oil-filled material is not suitable for soldering.
              The bushes are intended to be a light press-fit in the surrounding material and (I believe), are made with the bore vey slightly oversize … so that it shrinks to size when fitted.
              You need to ream the holes in your plate, carefully and accurately.
              Can you post a sketch of what you are making? … we may then be able to advise on technique.
              jason udall
                @jasonudall57142
                Flanged bushes?
                Widely used in thin plate..
                But as to soldering oilite…how would you propose degreasing it prior to soldering? .and then keeping the pores open ?
                #130230
                JohnF
                  @johnf59703
                  Michael, Depends on what you are making but I don't think that 1/8" will give a good enough alignment for the bushes? However why not solder in a steel tube then bore in situe to accept the bushes thus you will have a good alignment and you can use standard oilite bushes. No need for a large wall thickness possibly 1/16" would do–better if it was a little more but your decision depending on the item you are making.
                  John.
                  #130243
                  Diane Carney
                    @dianecarney30678
                    A post has been deleted on the request of a member.
                    A subsequent post was also deleted as without the first the second didn't made sense.
                    Diane
                    #130405
                    nigel jones 5
                      @nigeljones5
                      wouldnt delete my post when asked!!!
