Silver solder ?
Silver solder ?
Home › Forums › Beginners questions › Silver solder ?
  • #124092
    Packmule
      @packmule
      Is there any particular reason why parts are silver soldered instead of normal brazing?
      #6780
      Packmule
        @packmule
        #124093
          Silver Solder is available in a range of melting points; all lower than "normal" Brazing temperature.
          It is adaptable to very fine work.
          It flows very well, and makes neat joints.
          < etc >
          Some useful notes here
          Edited By Michael Gilligan on 08/07/2013 10:39:14
          #124098
          peter walton 1
            @peterwalton1
            The use of brazing rod on boilers is a no no as it will dezincify over time and could blow up!
            I suppose you could use a bronze brazing rod!
            Peter
            #124105
            Packmule
              @packmule
              Thanks Guys,
              knew there must be a reason , dont know ? ask yes
              Cheers Bob
              #124106
              MICHAEL WILLIAMS
                @michaelwilliams41215
                Silver solder :
                Melts more easily than brazing rod so relatively large jobs can be done easily with modest equipment . Also the lower melting temperature means that damage to typical copper boiler parts and brass / gunmetal assemblies is unlikely .
                Flows readily right through flanged joints et al whereas brazing rod tends to sit on the outer edges unless great care is taken and very adequate heat is available .
                Chemically is relatively inert so doesn't corrode away too rapidly in presence of combustion products or acidic water .
                Requires a simple relatively harmless flux in most cases .
                Will remelt relatively easily without too much deterioration of composition .
                Brazing :
                With adequate heating brazing is good for many ' garage ' type jobs of fixing things together and is relatively cheap .
                Historically was the only thing available for engineering work and a lot of early steam engine pipework was done with brazing . Reached a very fine art in manufacture of brewing equipment and stills .
                MikeW
                Edited By MICHAEL WILLIAMS on 08/07/2013 13:51:18
                #124112
                peter walton 1
                  @peterwalton1
                  Just been in the garage and noticed my pack of 'Sil-Phos' brazing rod, ok for car or gap filling jobs not sure it is of any use for boilers etc but the bees knees on the body work!
                  peter
                  #124149
                  Keith Hale
                    @keithhale68713
                    Why silver solder? Please bear with me !
                    There are several types of brazing alloy.
                    nickel brazing alloys – marine
                    gold brazing alloys – jet engines
                    palladium brazing alloys – jet engines
                    copper brazing alloys (includes brass and copper-phosphorus alloys eg silfos)
                    silver brazing alloys (silver solders)
                    Brazing defines the metal joining process not the alloy
                    Copper alloys are the cheapest and very versatile. So there has to be a very good reason to move away from them . That is invariably due to a technical reason. These include melting temperature, parent material combination, corrosion resistance, even colour or a combination.
                    The success of the process depends on correct joint design, heating technique and fluxing. If these criteria are not met no brazing alloy will work.
                    Peter, a word of caution. Silfos contains phosphorus. It appears to work well but combines with iron (in all steels) and nickel to create a very brittle intermetallic compound that can lead to catastrophic joint failure when stressed.
                    Copper phosphorus brazing alloys used to join copper nickel pipes on a submarine is thought to be the reason a submarine did not return from its' test dive.
                    keith
                    #124151
                    Keith Hale
                      @keithhale68713
                      The decision to use brazing as the metal joining process in preference to soldering or welding is based on technical reasons eg parent material combination, temperatures, strength, corrosion resistance.
                      Brazing defines the process not the alloy used.
                      There are several sorts of brazing alloy.
                      Nickel brazing alloys – marine, nuclear applications
                      gold and palladium brazing alloys – jet engines
                      copper brazing alloys (eg brass and silfos)
                      If the basic principles of the process – correct joint design, heating technique and fluxing – are not followed no brazing alloy will not work satisfactorily.
                      Peter a word of caution re silfos.
                      It contains phosphorus which will produce very brittle joints on steel and nickel bearing materials. Such a material is thought to be the reason a submarine did not return from its' test dive
                      Phosphorus does not like hot sulphur containing atmospheres eg boilers. your technical reason for using a silver brazing alloy (silver solder!)
                      #124152
                      CuP Alloys
                        @cupalloys
                        Hi there.
                        Brazing is a means of joining metal, as applies similarly to soldering and welding. It defines the process not the filler metal.
                        The decision to braze and the alloy used is decided by technical reasons eg temperatures involved, parent metal combination, strength, corrosion resistance, even colour.
                        If the basic principles of joint design, heating technique and fluxing are not followed, no brazing alloy will work satisfactorily.
                        There are several forms of brazing alloys.
                        Nickel brazing alloys – nuclear and marine applications
                        Gold and palladium brazing alloys – jet engines
                        copper brazing alloys (brass and copper phosphorus alloys eg silfos)
                        silver brazing alloys (silver solder)
                        The success of all depends on the same principles.
                        Peter – a word of caution re phosphorus containg alloys. They produce very brittle joints on parent materials containing iron or nickel. Such a material was used to braze copper nickel pipes on an american submarine. It did not return from its test dive.
                        Phosphorus bearing alloys corrode very quickly in hot sulphur containing atmospheres eg coal fire boilers. One of your technical reasons for using silver brazing alloy (silver solder!)
