SIEG Mini-Lathe DRCD to Manual Conversion Kit
Home › Forums › General Questions › SIEG Mini-Lathe DRCD to Manual Conversion Kit
  • #562793
    John Roach 1
      @johnroach1
      Hi All
      I notice Arceurotrade do this SIEG Mini-Lathe DRCD to Manual Conversion Kit..Was the original DRO that bad? I was thinking of doing the reverse ( changing the manual dials to DRO.. Any advice?
      thanks JR
      #28344
      John Roach 1
        @johnroach1
        #562795
        Howard Lewis
          @howardlewis46836
          My second hand Chester Conquest Super came with DRO on Cross and Top Slides.
          My only problem on a little used machine was that when it was needed, the batteries always seemed to be flat!
          The screws retaining the battery covers are small (and so easily lost), and I had problems obtaining batteries..
          A pity, since the DRO gave the choice between Metric and Imperial readout (On mine, the Leadscrews appear to be 20 tpi, if the DRO is to be believed, although the main Leadscrew is 1.5 mm pitch
          Chester quoted £100+ to convert to analogue Metric, involving Dials, Leadscrews and Cross Slide..
          Eventually, Arc supplied a kit for half that price. STILL not fitted, having obtained a supply of batteries..
          Maybe conversion would be the ideal opportunity to modify the new Cross Slide to take a Rear Toolpost, (and to make one? )
          The restriction is likely to be the Cross Slide hitting the Splash Back, but that is a bridge yet to crossed.
