A Jason says, increasing the lead helps engines run smoother on air.
….and he also suggests that adding lap may also make the engine run smoother on air.
It puzzled me why a model engine maker would add lap to the slide valve if they only intended to run the engine on compressed air.
Lap is used, as I understand it, to exploit the expansive properties of steam. Without lap a whole cylinderful of steam is used for each stroke of the piston. Adding lap, without going into detail, utilises the expansive properties of the steam resulting in the engine using less steam and thus being more efficient.
I think I can see what Jason is thinking, at high speeds and with considerable momentum does the engine need a whole cylinderful of air for each stroke?
Just my thoughts guys
Geoff
