Screws, how far from the edge?
Home › Forums › Beginners questions › Screws, how far from the edge?
  • #49715
    Goran Hosinsky
      @goranhosinsky61367
      I am making a 4-way tool post for 8 mm tools. I am planning to use M6 screws to hold the tools. If I center the screws on the tools, that is 4 mm from the edge, I will have 1 mm of untouched material between the hole and the edge. I do not know, if that is enough.I could move the screws in from the edge but then they would then not be centered on the tools, do not know if that would be a good idea, or I could use M5 screws giving me 1.5 mm margin – or a combination of both.I would appreciate any advise.
      Goran Canary Islands
      Edited By David Clark 1 on 12/03/2010 14:21:52
      #4998
      Goran Hosinsky
        @goranhosinsky61367
        #49719
        KWIL
          @kwil
          With this size of toolpost and 8mm tooling,  M5 is more than sufficient. Keep the screws centred on the tools.
