Screwcutting Crashes –
Home › Forums › Beginners questions › Screwcutting Crashes –
Viewing 10 posts - 26 through 35 (of 35 total)
  • #297657
    Phil H1
      @philh196021
      Dave,
      Just wondering = why not just cut the thread with a die? Was it just for fun that you decided to test you and your machine or simply no die at the required size?
      Phil H
      #297659
        Having a coffee break and pleased to report that the Hopper method is the best so far. You don't have to swivel the top-slide and therefore can get close to the chuck without worrying about sticky out bits hitting things. Also, cutting the thread from left to right with the lathe in reverse, the dreaded head crash can't happen. I'd assumed hopper-style that remembering to move both top-slide and cross-slide in proportion would be error prone. It's not!
        I'm well pleased with the shower of tips that came in answer to this question, not to mention what I picked up from watching Joe Pieczynski's videos.
        Thanks,
        PS. Martin, of course, is completely right about any lathe being better than no lathe. I started with a mini-lathe and found that incredibly interesting and useful. Trouble is tools are highly addictive and I am so weak. I could easily end up spending my days polishing a workshop full of expensive kit…
        #297716
        Hopper
          @hopper
          Good result! Happy latheing. smiley
          Yes, time involved in change gear fiddling about is one reason many choose to use dies held in a tailstock holder for smaller threads and save the screwcutting for special jobs.
          #297741
            Now you are using the top slide parallel, slide it further back on the cross slide. This will allow you to mount your tool the right way up but behind the work. That way you will not have the height issue associated with mounting the tool upside down, and just run in reverse. This is putting the tool in a similar position to that I showed earlier except you will be using a standard tool rather than an internal one.
            #297770
            Neil Lickfold
              @neillickfold44316
              You will find that if you use either and extended too bit in a larger block, or use an insert threading tool, you will be further away from the chuck diameter wise.
              To not crash into the chuck, when I installed the VFD, I also added a micro switch. This is just set up to trip when the carriage gets to the desired position.The lathe motor stops and so does the carriage. If there is a run out (thread relief area) then retract the tool. Then simple turn the switch to reverse. It goes back and ready for another cut when in the forward position again.
              Previously I used to do the marker pen thing for internal threading and just looking at the thread relief when external threading. I like to use the angled approach when threading, except when I have some special situations where an angled retraction in internal thread can cause damage to the end face. In these cases, I leave the compound on zero.
                Posted by Phil Hale 1 on 11/05/2017 16:38:56:
                Dave,
                Phil H
                Hi Phil,
                Missed your question yesterday. The answer is a bit of both, mainly educational. Usually for real work I cut small threads (<10mm) with a die, and try to keep things simple.
                However, I'm keen to improve my metalworking skills because I'm self-taught. In this case, I'm making a trial brass union joint. It happens that the scrap of brass hexagon I have is 3/8" so I'm putting an M9x1 thread on it. It's an unusual one-off and I don't have a die. So it's an opportunity to push what I know about the lathe. If it goes well I shall have proved I can make a non-standard part. If it goes badly I can get help off the forum and have another go. It's a good job I don't have to make a living like this.
                I've already bodged a M9x1 tap out of silver steel to do the union's female. Hardening it correctly is yet another self test because my blowlamp skills are wobbly too. Will it cut? Who knows. Practice, more practice.
                I enjoy setting myself this kind of exercise. It's a meaningful challenge without serious hassle if I get it wrong.
                Cheers,
                  Posted by JasonB on 12/05/2017 07:30:47:
                  Thanks Jason, that's another improvement. I shall try that this afternoon. It's 'quite interesting' how many different ways there are to do screw-cutting and the obvious one isn't necessarily the best. I'm glad I asked.
                  Cheers,
                    Just an update. Cutting from the rear as described by JasonB with dials twirled as per Hopper works extremely well. I shall stick with this method from now on.
                    Neil Lickfold suggested using a micro-switch to cut the power on the way in. I think that's a practical proposition. I experimented with how quickly my lathe stops when the power is cut. At 480 rpm the saddle carries on up the bed for 25mm! However, at a more reasonable 200 rpm (which is as fast as I think I would ever screw-cut), the saddle stops within 2mm of losing power. That's fast enough to avoid a crash. The much greater distance travelled at 480rpm shows how much energy is stored in a quickly turning chuck. I wouldn't want to tangle with one at 2500 rpm!
                    Thanks again for all the good advice
                    Cheers,
                    Dave.
                    Edited By SillyOldDuffer on 12/05/2017 19:11:21
                    #297843
                    Neil Lickfold
                      @neillickfold44316
                      Dave, If you have a VFD Variable Frequency Drive, they will stop with in 1 second from 400 rpm aprox. I screw cut at about 200 rpm to 400 rpm.
                      Martin Connelly
                        @martinconnelly55370
                        I have a micro switch mounted on an aluminium block that clamps on to the lathe bed and can easily be repositioned to suit collets, 4 jaw or 3 jaw chuck as appropriate. It is a home switch for CNC and a limit switch at the same time. It has saved me from crashing bits together a number of times when using manual data input to move the carriage around.
                        Martin C
