rotary broaching
rotary broaching
Home › Forums › Workshop Tools and Tooling › rotary broaching
  • #449380
    David Taylor 4
      @davidtaylor4
      I made up the Hemmingway rotary broach kit and it works well using a male broach. Reading the proprietary manufacturers literature they claim that a female broach can be made using the male .
      I tried this and the result did work but of course it lacks clearance and is a tough go in use.
      Any ideas how to give clearance in a female broach with out using a file?
      #19607
      David Taylor 4
        @davidtaylor4
        extrernal
        #449405
        not done it yet
          @notdoneityet
          Make it with a slightly over-sized male broach?
          #449412
          Martin Kyte
            @martinkyte99762
            Posted by not done it yet on 28/01/2020 07:13:17:
            That only gives you a larger sized, straight sided broach with no clearence. A rotary broach wobbles (which is why it's sometimes called a wobble broach so for a female broach the hole down the middle needs to open up to give clearence. Hence the OP's question.
            I don't know the answer because I would use a file. Possibly using a male broach to create the initial hole so NDIY is not entirely on another planet.
            regards Martin
            #449462
            David Taylor 4
              @davidtaylor4
              One attempt I made was to mount the broach on the top slide . I set the top slide over at 1.5 degrees and feed into the female blank. I thought it might give some clearance but it was not obvious that it did.
              Filing clearance in a .06"A/F hex hole is not easy.
              The attraction of the rotary broach was to produce small hexagons for which bar stock is no longer available and avoid setting up the mill with dividing head.
              #449465
              Grindstone Cowboy
                @grindstonecowboy
                I'm not entirely sure I understand the female broach part, but could you grind relief with a Dremel or die-grinder?
                #449473
                Howard Lewis
                  @howardlewis46836
                  Surely, if you use a male wobble broach to produce a hole, the male broach will have clearance, and cut easily, but the hole will have parallel sides, so that there is no clearance for a cutting edge?
                  To provide clearance behind the cutting edge, the female broach would need to have the cutting edge as the smallest dimension, with a hole behind it to allow the swarf to fall away.
                  #449483
                  old mart
                    @oldmart
                    If you are lucky enough to have a mill and rotary table, why would you ever need a female broach?
