Posted by Nigel Graham 2 on 08/05/2021 17:18:28:
… just paused to look more closely at the wireless in the kitchen. It has a telescopic aerial and no socket for a further aerial.
… Not brilliant audio quality I don't expect anyway; but ample radio signal. This was so with the aerial erect or closed and folded down to its clips, on both stations. All that happened in the closed state was my shielding the signal to some extent.
The weather? Thick overcast.
A proper plug and socket isn't strictly needed to connect an external antenna. Just wrap a few inches of the coax centre conductor around the base of the telescopic aerial. RF best practice isn't essential – with luck the bodge only has to improve a marginal signal due to the radio being inside the house.
Of course, for best FM reception, go the whole hog. That means putting an antenna high up outside, at least 2 wavelengths away from any nearby structure, maybe a beam aimed carefully at the transmitter, with a pre-amplifier, and connected to a better FM receiver with a proper antenna socket. ega's leaflet covers the ground rather well, and goes so far as to suggest rotating the beam. This contrasts sharply with buying a cheap FM portable and hoping it will work inside a house. Do it properly and the antenna might well cost more than the radio. Much depends on location relative to the transmitter: these don't put down a uniform signal in neat circles. This map shows Mendip's patchy service area. Good signal up several Welsh valleys, and South Dartmoor, but no good for Yeovil, Bristol and Bath, all shielded by high ground.
It's not really possible to tell how strong an FM radio signal is just by listening to it. Radios are fitted with Automatic Gain Control that works hard to maintain the same output whatever the input level. Radios are designed to fool the ear – don't trust it!
AGC fails causing distorted audio when the input is too strong or too weak. Too weak also causes drop outs, where noise intrudes – usually distant weak stations and/or hash. Nigel's symptoms match FM radios demodulating marginally weak signals. I have the same problem: my portable radios work OK in some rooms and are hopeless in others. They all work perfectly in the garden!
Houses are dreadful for radio reception. First the signal arrives mis-phased due to bouncing or diffracting off all the other buildings, hills, trees, lakes, or whatever at ground level between the house and the transmitter. Inside the house it gets worse. Apart from loads of domestic electrical noise, the incoming signal bounces off internal walls, water pipes, electric wiring, metal window-frames, girders, aluminium curtain rails, people, and pretty much anything else bigger than an FM 1/4 wave. What the telescopic aerial gets is a mish-mash depending on a multitude of variables, any of which can alter path lengths causing signal strength to rise and fall mysteriously. Weather can effect FM but it's associated with Sporadic E and Ducting, both relatively unusual. One explanation is folliage. In winter it dies back, which could strengthen subtractive paths; in summer, the subtractive part is weakened.
Russell and I have both suggested the multiple path problem: we're not making it up! The answer is a good antenna. At roof height most things that change path length by bouncing are below the antenna, as is most electric noise.
In communications radio the antenna is the most important part of the system. A high-performance receiver and powerful transmitter connected to a town-centre indoor antenna are easily outperformed by modest equipment connected to an efficient outdoor aerial high up in a good location well clear of obstacles and electrical noise. Most radio amateurs are constrained by their antennas – gardens not big enough, and cluttered take-off due to close neighbours, some of whom run unfiltered VFDs! Off with their heads!
Edited By SillyOldDuffer on 10/05/2021 11:09:07
