This thread brought back some memories. I had several Imps long ago, and have to say I liked the car. I had one special version which had an 'Estate Car' rear end (not the van), and a digital speedo (this was around the mid 1970's). Contrary to some of the opinions here, it handled well. My opinion is that the weight of the all-aluminium engine/gearbox at the rear was fairly well balanced by the fuel tank at the front of the car, and the weight of the driver and front seat passenger.
It was always a fairly easy car to work on. I changed the clutch (first UK car to use a diaphragm clutch!) on one single-handed at the side of the road. Simply support the engine and wheel the car away. The job I always hated was replacing the rubber drive doughnuts, because they had to be compressed using a special tool (actually a big jubilee clip), and it always seemed to be a PITA to get the bolts back in!
Tappet adjustment was a la Jaguar XK, by replacing shims under the tappet buckets – I eventually ended up with a bucketful of the shims collected from scrapyards, because you had to fit a shim, assemble it all, measure the gaps, calculate the actual shim size needed, then take it all apart to fit the correct one – but it was OK once it was done.
The standard 875cc engine went quite well, but I much preferred the twin-carb 998cc – much more go!
At one time I worked on the Rapier missile system. At that time, the generator unit for the system was powered by a variation of the Coventry Climax engine, which was originally developed (I believe) for fire-engine pumps, and was later developed into the Imp engine.
