Remote control for 3 phase inverter.
Home Forums General Questions Remote control for 3 phase inverter.
Viewing 23 posts - 1 through 23 (of 23 total)
  • #21953
    The Merry Miller
      @themerrymiller
      The Merry Miller
        @themerrymiller
        I have obtained an Omron 3G3MV 3 phase inverter and I would like to make a remote control pendant or suchlike to interface with it.
        Are there any forum members out there who may have carried out this mod. whose brains I may be able to pick.
        Len.P.
        #76467
        KWIL
          @kwil
          Len
          Have you got the manual? This gives the diagram for the remote and what switches you will need to set up. Most Inverters have a similar control circuit ( I have four ) and there is no real differences between the manufacturers.
          Gavin Osman advertises these inverters on http://www.homeworkshop.org.uk and no doubt he could help as well.
          K
          #76471
          The Merry Miller
            @themerrymiller
            Hi Kwil,
            I have just downloaded a short manual and also the quick start guide.
            The inverter arrived this morning and hopefully the Marelli 3 phase motor this afternoon.
            I will now study the manual and see whats going on.
            Len. P.
            #76473
            joegib
              @joegib
              Here’s a neat VFD remote control diagram posted here by David Thomas 6:
              Joe
              #76475
              The Merry Miller
                @themerrymiller
                Well the Marelli motor has just arrived, took it out of the box, lovely colour!, i’ts going back tomorrow, they have sent the wrong one.
                Len.P.
                #122447
                Sub Mandrel
                  @submandrel
                  I'm soon to be wiring up a pendant for a jaguar cub motor.
                  My reading is that I need (aside from eth speed control pot):
                  red stop button – momentary switch wired to one of X1-3 programmed as 'coast to stop'
                  Toggel switch jog/normal wired to one of X1-3 programmed as 'Jog mode'
                  Toggle switch fwd-off-rvs the common terminal wired to CM via a momentary green start switch
                  I am I correct that programming the 3-wire 'hold mode' this will allow the green start switch to activate fwd or rvs until the red switch is pressed?
                  Thanks
                  David Jupp
                    @davidjupp51506
                    Neil – that doesn't sound quite right –
                    Fwd-off-rvs, if wired via momentary start p/b, then the 'off' of the 3 position switch can't do anything (except act as a disable).
                    Not familiar with the Jaguar – some inverters offer more than one switching mode dependent on how you want to control it.
                    One that I use here is set to mimic a NVR contactor behaviour (3 wire mode) – n/o button to start, n/c button (and any interlock switches) to stop. The same inverter can also be set to have a single contact – closed for run, open for stop (2 wire mode). On my drive, fwd/rev is done via a simple on/off toggle switch, as is jog mode.
                    Mine is not a Jaguar drive though – so the handbook should be your ultimate guide.
                    #122463
                    Chris Heapy
                      @chrisheapy71135
                      Sounds a bit complicated, both mine have simply a 3-position switch (Fwd, Stop, Rev) and a pot for speed. That's it.
                      Chris
                      #122484
                      Brian O’Connor
                        @brianoconnor49474
                        I'm afraid that I'm unable to help Len P, but for Neil here is the circuit diagram of the remote pendant that I made for my Jaguar Cub VFD. In addition to the usual switches and a 5K pot you will need a 24v single-pole relay.
                        Come to think of it, perhaps Len can rig up something similar for his VFD.
                        #122486
                        Brian O’Connor
                          @brianoconnor49474
                          This crappy website strikes again. I have tried opening the image in my above post and find that I am unable to, so presumably no-one else can either. I put it there by pasting the image from the clipboard. When creating the posting the only way that I could view what I had pasted was to click on the icon, select copy and then paste into a blank document, but once posted clicking on it has no effect.
                          Does anyone know how to get round the problem? I have the diagram as a Word document and as a PDF. If all else fails I could always send it to anyone interested via a PM.
                          #122492
                          The Merry Miller
                            @themerrymiller
                            Hi Brian,
                            The remote unit I built many moons ago now is fitted to the right hand side of my Tom Senior M1 mill.
                            I did post images of it on this site but I can't locate them now, not even in my albums.
                            As a matter of interest many years ago when I was designing control panels for aircraft and ships we had procedures and ergonomics to consider that were laid down in Def-Standards (MOD were hot on this).
                            Most parameters, like to increase a function's value, a control dial was rotated in a clockwise direction, to decrease one would turn the dial anti-clockwise.
                            This, most of us see as commense sense.
                            What makes me wince is when I see switches labeled up such that to operate REVERSE, the switch lever moves from left to right and vice versa when good ergonomics dictates that when selecting FORWARD, the switch lever should move from left to right.
                            You even see this on proprietary gear being sold.
                            I know a lot of you would say, what the hell does it matter.
                            I say it's just a matter of good engineering design.
                            Anyway that's my grouse for today.
                            Love to you all!!!
                            Len. P.
                            #122494
                            OuBallie
                              @ouballie
                              Len P,
                              You have two Left to Rights, or I'm missing something.
                              Geoff – Good day out yesterday.
                              #122497
                              The Merry Miller
                                @themerrymiller
                                Possibly Oub!
                                Len.P.
                                #122505
                                frank brown
                                  @frankbrown22225
                                  This lefthanded/righthanded business caused the Three Mile Island nuclear accident. The two adjacent control boards for the two reactors were mirror images of each other. The staff had actually put coke cans and tennis balls over the levers to differentiate between them!!!
                                  Frank
                                  #122509
                                  Sub Mandrel
                                    @submandrel
                                    It seems that different inverters have very different controls. Brian – I've sent you a PM with my email thanks for the offer!
                                    I do wonder if a relay will be needed.
                                    Thanks
                                    Bazyle
                                      @bazyle
                                      It all starts to go wrong with them furriners who think up = on
                                      #122553
                                      OuBallie
                                        @ouballie
                                        Oops!
                                        I've just read Len.P.'s post again about ledt ro right, and I misread it.
                                        Just not paying attention and brain refusing to co-operate again.
                                        Nothing unusual then for me lately
                                        Geoff – More office work today.
                                        #122554
                                        Brian O’Connor
                                          @brianoconnor49474
                                          Neil,
                                          I have sent you the circuit diagram of my Jaguar remote pendant via email. The relay is there as a safety device. When the Start button is pressed the relay operates and holds itself on, maintaining the power to the machine. If power is lost the relay drops out and the machine can only be started again once power is restored by pressing the Start button. Without the relay, if power is lost and the operator forgets to switch off, then when power is restored the machine will start on its own, just as one's grandson is saying "What's that bit for, Grandad?"
                                          #122577
                                          Sub Mandrel
                                            @submandrel
                                            Hi Brian,
                                            Thanks, email recieved.
                                            > When power is restored the machine will start on its own, just as one's grandson is saying
                                            I think you have to conciously set one of the parameters to allow the motor to self-start, but the arrangement I was hoping for would require the start button to be pushed too.
                                            Belt and braces does no harm!
                                            Neil;
                                            #122933
                                            Sub Mandrel
                                              @submandrel
                                              Well I've got a pendant that will start and run forward or reverse, but I can't get the hold function to work. It just coasts to a stop whenever I release the start button.
                                              A 'John S.' has offered sage advice here : **LINK** in the past, but I'm still struggling. If its 'our John S.' I fear he is on holiday…
                                              Has anyone got this to work?
                                                Posted by The Merry Miller on 17/06/2013 13:58:29:
                                                Len,
                                                One of the classic examples of the science of Ergonomics; very well documented by K.F.H. Murrell … The problem with ships [and with power stations, etc.] is that some controls are valves for liquid, or steam, or gas, or vacuum, which [just like the conventional water tap] increase flow when turned anti-clockwise. Murrell realised that, when abstracted to a control panel, these "taps" are better treated as "knobs" … meaning that all rotary controls are arranged to increase by clockwise rotation.
                                                In emergency situations, people revert to instinct when turning knobs; and experiments showed that instinct was to turn knobs anticlockwise to decrease [i.e. to make safe]
                                                … of course; the fun starts when either (a) it is "evident" that a particular control is a tap/valve or, (b) when the "make safe" requirement is to increase something.
                                                Edited By Michael Gilligan on 23/06/2013 07:41:35
                                                #123047
                                                Sub Mandrel
                                                  @submandrel
                                                  I now have a fully working remote pendant with the Jaguar Cub.
                                                  It turned out that I hadn't programmed F02 to 1, but it was still obeying external FWD/REV commands!
                                                  I programmed F02 and now it works, including jog and e-stop.
                                                  A few notes:
                                                  You can use a changeover switch to switch the run button between FWD and REV, rather than having two start buttons.
                                                  The stop button must interrupt the +24V/PLC supply to the run/jog buttons, otherwise the motor will run when the start button is pushed even though the stop circuit is broken, though it will stop when the start button is released – this is not good.
                                                  Default jog speed is zero so it won't work until you enter a jog speed. X2 is preset to operate as a jog control.
                                                  Now I just need to fit all this gubbins to the lathe.
